Torque Specs, DTC's, etc etc etc
Old 06-12-2012, 07:17 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Torque Specs, DTC's, etc etc etc
For those of you that missed it (I've gotten a bunch of inquiries lately), I've moved everything to a dropbox folder, and you can access it via my Facebook page (facebook.com/DavidFarmerRacing). You may have to scroll a bunch to find everything, or PM me at facebook if you can't find what you need.
Here are a few of the most popular
https://dl.dropbox.com/u/1634366/C6Z06-Torque.pdf C6Z06 torques
https://dl.dropbox.com/u/1634366/C6-Torque-Manual.PDF C6 manual torques
https://dl.dropbox.com/u/1634366/C6-DTC.PDF C6 DTC's
https://dl.dropbox.com/u/1634366/C5torque.pdf C5 torques
https://dl.dropbox.com/u/1634366/c5-dtc.pdf C5 DTC's
https://dl.dropbox.com/u/1634366/c5-fuse.pdf C5 Fuse layout
https://dl.dropbox.com/u/1634366/C5-PartsManual.pdf C5 parts manual (large)
https://dl.dropbox.com/u/1634366/accusump.pdf accusump info
https://dl.dropbox.com/u/1634366/align.pdf DIY alignment guide
https://dl.dropbox.com/u/1634366/apr-wheel-stud.pdf APR stud info
https://dl.dropbox.com/u/1634366/quartermaster-C5.pdf quartermaster clutch
https://dl.dropbox.com/u/1634366/SuspensionGuide.pdf misc suspension advice
https://dl.dropbox.com/u/1634366/T-5...ice_Manual.pdf transmission service manual
https://dl.dropbox.com/u/1634366/weatherhead.pdf
https://dl.dropbox.com/u/1634366/weatherhead2.pdf Weatherhead/NAPA brake fittings
https://dl.dropbox.com/u/1634366/diff.pdf fittings for Diff cooler
https://dl.dropbox.com/u/1634366/FluidairParker.pdf Parker fittings misc
Old 06-12-2012, 09:53 PM
383's Avatar
Thank you sir
Old 06-12-2012, 10:40 PM
taken19
Track Junky
taken19's Avatar
It's good to have all of your invaluable information available again. Thanks!
Old 06-12-2012, 11:34 PM
BEZ06
BEZ06's Avatar
Thanks, David!!
Very valuable info, and I have missed not having access through your old site.
Bob
Old 06-13-2012, 04:52 AM
stevensa
stevensa's Avatar
Thanks for posting this extremely useful info.
Old 06-13-2012, 09:39 AM
travisnd
travisnd's Avatar
Yes... Thank You David I printed your torque specs sheet out years ago when I got my first C5. It's the first thing in the service binder I created for the car. After all these years I pretty much have it memorized by now
Old 06-14-2012, 02:04 PM
el es tu
el es tu's Avatar
Its great to see this stuff is available again!
David - Ill be emailing you in a few weeks on those decals - simpson is backordered on my helmet until next month so Im just waiting to finalize the dimensions thatll be needed!
To Torque Specs, DTC's, etc etc etc
Quick Reply: Torque Specs, DTC's, etc etc etc
