Brake pad issue
Old 01-20-2013, 04:52 PM
VTcorvette
VTcorvette's Avatar
Default Brake pad issue
I'm not sure what to look for on this and could use some help. I have a GS that I put new rotors and Stop Tech pads on for the track. I inspected the brakes after two track days. The rear look good. The front have very uneven wear. The pads are badly tapered, very worn on the bottom and a lot of meterial on the top. This is viewing the pad from looking through the back side of the caliper.
Any help would be greatly appreciated. The car has 5000 miles on it.
Old 01-20-2013, 06:13 PM
taken19
Track Junky
taken19's Avatar
Please post pics so we can help diagnose.
Old 01-20-2013, 06:59 PM
VTcorvette
VTcorvette's Avatar
These are one piece pads, not padlets. You can see the grove depth in the pad at the top versus the bottom.
Old 01-21-2013, 11:17 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Can we see a picture of the pad out of the caliper please.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 01-21-2013, 02:28 PM
63Corvette
63Corvette's Avatar
You don't say WHICH Stoptech pads, so I am assuming Street Performance pads. If so, then I would think that you need to upgrade to RACE pads, and Adam can help you there.....
Old 01-21-2013, 04:34 PM
VTcorvette
VTcorvette's Avatar
63Corvette, you are correct. Stop Tech Street Performance pads.
Adam, I will get some pictures when I replace the pads. The bottom of the outboard pad is too worn for another track day. I will send you an email to see what you suggest.
Thanks.
To Brake pad issue
Quick Reply: Brake pad issue
