Setting up an LS powered 86 camaro for Drag/AutoX/HPDE info?
Old 01-28-2013, 12:11 PM
yow
yow's Avatar
Default Setting up an LS powered 86 camaro for Drag/AutoX/HPDE info?
A buddy just got an old 86 camaro and we will be setting it up as an all around track car. He drag races and I do HPDEs. His plans are to do a 5.3L turbo LS swap with auto trans and manual valve body. He has a few ideas and wants to do a 9" in the rear, disk brakes, and maybe an adjustable 4 link rear end.
Where can I get some good information on setting this car up for an all round car? He wants to be fast at the drag while still competitive at autox and on the road course. We are just looking for a place to start reading and researching.
Thanks for any input!
Old 01-28-2013, 04:37 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
not happening
Old 01-28-2013, 05:03 PM
Aardwolf
Aardwolf's Avatar
I do a mix of track events with mine and it does alright. Optimizing for each type of racing or each track would be worth it. I typically leave mine setup for road course HPDE/NASA time trial which is a big compromise for drag racing. If I wanted to get the most out of it for drag I would really need to spend time switching things around.
Old 01-29-2013, 07:36 PM
FASTFATBOY
FASTFATBOY's Avatar
www.frrax.com
Old 01-29-2013, 08:10 PM
yow
yow's Avatar
Thanks for the input! We've got a lot to sort out but plenty of time to work out kinks.
To Setting up an LS powered 86 camaro for Drag/AutoX/HPDE info?
Quick Reply: Setting up an LS powered 86 camaro for Drag/AutoX/HPDE info?
