GoPro harness bar camera mount
Old 05-15-2013, 10:33 AM
QUIKAG
QUIKAG's Avatar
Default GoPro harness bar camera mount
Does anyone have a recommendation for a good GoPro camera mount for a harness bar?
Old 05-15-2013, 12:09 PM
Screamin Z
Screamin Z's Avatar
Mine is just a round piece of pipe slightly larger than the diameter of the harness bar with a couple bolts threaded through some nuts to hold it in place on the bar. Then a flat piece of metal with a hole for the camera to mount to.
Pretty easy to make if you have the tools. Dont think I have a photo of it.
Old 05-15-2013, 12:22 PM
QUIKAG
QUIKAG's Avatar
Thanks, Screamin Z. I actually found a GoPro roll cage/harness bar mount sold by GoPro on Amazon for less than $20. So, since I'm relatively lazy, I'm going to try that out and see how it works. I searched a few other threads on here and supposedly it works with the Shark bar that I have. Thanks again.
Old 05-15-2013, 12:49 PM
TorontoC6
TorontoC6's Avatar
I used the Gopro roll bar bracket to mount to the harness bar. Worked fine.
Old 05-15-2013, 12:59 PM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
Do you have a link or product number? Thanks!
Old 05-15-2013, 02:34 PM
QUIKAG
QUIKAG's Avatar
Amazon.com: GoPro Roll Bar Mount for HERO Cameras: Camera & Photo Amazon.com: GoPro Roll Bar Mount for HERO Cameras: Camera & Photo
Old 05-15-2013, 02:54 PM
Hat_Trick_Hokie
Thanks!
Old 05-15-2013, 04:44 PM
skxf430
skxf430's Avatar
Yes, the Gopro rollbar mount works well enough. Got mine off Amazon too.
Old 05-15-2013, 10:49 PM
dvandentop
dvandentop's Avatar
nice need to get one as well
To GoPro harness bar camera mount
Quick Reply: GoPro harness bar camera mount
