Drivetrain slop?
Drivetrain slop?
Used to feel pretty tight, but it seems at low rpm slouching it around corners feels like the driveshaft is flopping all over. Once some rpms hit, it's fine. Is this the rubber couplings in the torque tube?
Everyone should read the thread in the link before you start making uninformed upgrades.
And for the record, I have been running the BMW 12mm ones for years but change them every 2 or 3 years. As far as I can figure out, Lemforder is the OEM for BMW and GM, I have also used the Febi version but the Lemforder is different. I didn't have any issues with the Febi but have stuck with the Lemforder for the last two replacements.
Drive Shaft Flex Joint K1020-31191
Description: 12mm Bolt 110 mm diameter : Uses (6) 12 x 1.5 x 58 bolt.
Brand: Lemforder
Trans Type: 5-Speed
Vehicle: 1998 BMW 318ti
Engine - Chassis:
M44 : E36
http://forums.corvetteforum.com/c5-t...couplings.html
Brand: Lemforder
Trans Type: 5-Speed
Engine - Chassis:
M44 : E36
Received 1,254 Likes
2016 C5 of Year Finalist
I run the RPM (Driveshaft Shop) couplings alum. I have had good
luck with them and my high hp 346.
