Tire pressure guage advice needed
Old 09-29-2013, 08:16 PM
Charley Hoyt
Charley Hoyt's Avatar
Default Tire pressure guage advice needed
I finally found a tire pressure guage that I really liked .... Until this weekend. I have an electronic guage from Griot's Garage that reads in .1 lb increments... Which has been great but then the batteries died. I replaced them, and everything was working fine. Then while I was at the track this weekend after checking two tires it went dead. I had to barrow gauges all day long. So at this point I am thinking I need a good guage that does not need batteries to work. At the track I used one from Longacres that was really nice but I am not sure which model it was.
What gauges have you had good luck with?
Charley
Old 09-29-2013, 08:37 PM
Aardwolf
Aardwolf's Avatar
I have a Joes Racing gauge that has been solid and isn't over costly.
Amazon.com: Joes Racing 32307 (0-60) PSI Tire Pressure Gauge: Automotive Amazon.com: Joes Racing 32307 (0-60) PSI Tire Pressure Gauge: Automotive
Old 09-29-2013, 10:30 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
That is what I had and I like it a lot until I ran over it. Just haven't gotten around to getting another one.
Old 09-30-2013, 12:10 AM
db2xpert
db2xpert's Avatar
Joe's also makes a digital gauge.
Have one, really like it.
Old 09-30-2013, 12:13 AM
skxf430
skxf430's Avatar
Longacres are great. Bigger the dial the better, and get the one with the angled chuck.
Old 09-30-2013, 12:16 AM
rfn026
rfn026's Avatar
I actually wrote a column about tire gauges. Here it is. The main thing is that once you start using a certain gauge never use another one. Most gauges aren't very accurate but they're all pretty reliable. Get three gauges and check the same tire. You'll see what I'm talking about.
btw - Get a gauge that allows you to bleed air out of the tire. I seem to be bleeding air out all day trying to get my pressures to 32 lbs. hot.
Richard Newton
Old 09-30-2013, 09:11 AM
Charley Hoyt
Thanks.
Charley Hoyt
Which one did you have the Griot's or Joe's?
Old 09-30-2013, 09:13 AM
Charley Hoyt
Thanks. Are the Magnums acceptable? Or is it worth the extra cost for the Pro?
Old 09-30-2013, 09:31 AM
Charley Hoyt
Richard Newton
Thanks Richard.
Old 09-30-2013, 09:32 AM
Bill32
Bill32's Avatar
I won't use a digital at the track.
I have 5 dial gauges, 4, 0-30 and one 0-60.
From using them for many years:
The absolute best is the Longacre large dial (I have 2 of them) , the large dial is easy to read, important on our open wheel stuff where we adjust at 1/2 psi at times.
Intercomp - Very accurate but has a buffering valve that slows the needle while it reads the pressure, a bit frustrating.
Joe's - I have one in the shop, it's a good gauge but not the quality of a Longacre.
RebCo - OK gauge, inexpensive. Would be OK for the "occasional trackday guy".
If you want a serious gauge, get the Longacre. Second would be the Joe's that Aardwolf posted.
If you're doing serious racing, you can have the gauge calibration checked yearly and a good welding supply shop.
Old 09-30-2013, 01:21 PM
Captain Buddha
Captain Buddha's Avatar
Richard Newton
That's my philosophy too. I'll let someone borrow my gage but I'll only borrow someone else's gage in a pinch. And a plus one for a bleeder gage.
Old 09-30-2013, 08:36 PM
RaleighSS
RaleighSS's Avatar
I have the Longacre small gauge .... has worked a couple years for me. I keep it in a padded box when not in use or transporting .... LA50412 for like 45 bucks on amazon
To Tire pressure guage advice needed
Quick Reply: Tire pressure guage advice needed
