The A4 to MN12 conversion is DONE!!
Old 01-17-2014, 05:55 PM
Bluefire
Bluefire's Avatar
Default The A4 to MN12 conversion is DONE!!
I have a highly modified 03, A4 Coupe with a solid H/C package (420 rwhp/392 rwtq) I have been tracking it for ~1.5 years. The 2800 stall was killing the trans with heat, even with an 25-plate aftermarket cooler. So.....
I collected all of the parts and this week my mechanic/friend Tom Wong (Wong's Performance Engineering) converted my A4 to an MN12!!! It's an RPM, T56, Stage 5, LS6 clutch, new C6 shifter, and a new pedal. The conversion is A LOT of work. Tom completed it in 3.5 days. The result is excellence. It drives like a dream.
Time for some heel/toe (ball/side) downshift practice in preparation for the new track season.
Tom's work is "top-shelf". BTW, he also built my beast of a motor. I can't thank him enough for the professional job he did.
Thank you Tom!!!
Quick Reply: The A4 to MN12 conversion is DONE!!
