Sway bar question for C5Z
Old 02-14-2014, 10:22 AM
555ss
555ss's Avatar
Default Sway bar question for C5Z
I am looking for a sway bar kit for our 2 C5Z the track only cars.
The Pfadt heavy rate that I want are back ordered for an additional 90 days that is on an order placed in september.
Do you guys have any recomondations as we start racing in early april and with spherical bearings and stock bars/ springs they do not turn in well. I would like adjustable/ tuneable bars
I don't want to use coil overs cost too many points in our run groups and I have heard too many issues with broken mounts.
Old 02-14-2014, 10:56 AM
Bad Karma
Bad Karma's Avatar
If you're going PFADT Heavy Rate, probably the only thing close are T1 bars.
Old 02-14-2014, 01:35 PM
troyguitar
troyguitar's Avatar
I cheaped out and got the pfadt johnny oconnell ones. According to pfadt they are very similar to T1 but are 2/3 the cost. Unfortunately I haven't tried them yet to give you any sort of review. I'll be running the JOC shocks too with stock C5Z springs and delrin bushings all around as a baseline setup.
Old 02-14-2014, 01:47 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
We have our G1 bars on the shelf and CF members do get a discount on the package!
http://www.lgmotorsports.com/product...oducts_id=2208
Proven design that will stiffen the car, and should be the first step on any C5 car before doing shocks or springs.
I can't speak for the points in the groups you run in....but broken mounts?
I have had ZERO G2 coil over/frame mount failures in the last 10 years.
Old 02-14-2014, 04:18 PM
RDnomorecobra
RDnomorecobra's Avatar
What's the CF discount?
and are they poly bushings or rubber with this LG kit?
Old 02-14-2014, 05:43 PM
Former Vendor
It is a hard durometer rubber with lining inside.
Forum members receive $85 off, you must tell your sales person when you order.
Old 02-15-2014, 12:11 AM
REVHARD
REVHARD's Avatar
It was a difficult decision between the JOC phadt sways and the GM T1. The Phadt are complete for $625 and the T1's are another couple hundred more. It may be petty and I may get some flack, but I just couldn't do the bright yellow bar being visible from the rear of my car so I went with the LG T1. If the Phadts were blue, black or grey it would be much more subtle. They are priced right but my OCD would have got the better of me.
Old 02-15-2014, 07:01 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I went with the T1 bars and haven't looked back. Good stuff!
Old 02-15-2014, 12:30 PM
troyguitar
troyguitar's Avatar
I actually like the yellow enough that I am making it part of my theme and will be painting the tow hooks and brake calipers yellow to match.
Old 02-15-2014, 12:59 PM
jd86L98
jd86L98's Avatar
I need new bushings for my T1 bars will these work?
Old 02-17-2014, 08:52 AM
Former Vendor
Yes
Old 02-17-2014, 10:22 AM
555ss
555ss's Avatar
thank you all for your replys I am still thinking it over.....
Old 02-17-2014, 11:14 AM
Rookieracer
Support Corvetteforum!
Rookieracer's Avatar
http://forums.corvetteforum.com/c5-p...-links-gm.html
http://forums.corvetteforum.com/c5-p...ale-socal.html
To Sway bar question for C5Z
Quick Reply: Sway bar question for C5Z
