69 Big block #'s matching
69 Corvette -Coupe All original - Numbers match - Body has NEVER been hit. Original paint, shines beautiful but it is 45 years old with a few chips and nicks. This car has had a complete mechanical restoration. Including frame off rebuild of all original drive train. Stainless steel brakes and fuel lines. Complete new exhaust, fuel tank, cooling system. Restoration has less than 500 miles. Original carbs rebuilt by Chuck Smith. Engine rebuilt by High Performance Engines. Transmission and rear end rebuilt. N.O.S. GM rotors. Original rally wheels powder coated. Original 69 trim rings - not repos. Red Line Radial Tires. All new Bushings and Suspension - Ball joints - tie rods, and shocks. Frame and all suspension pieces painted with 2 coats black epoxy primer - topped by 2 coats black semi gloss urethane enamel. Interior is all original - except Al Knocks seat covers and carpets. This car has never been modified or raced in its life.
This is a Canadian Car, with GM documentation - Also has the original Gas Tank with Tank sticker. This is NOT a Trailer Queen - "Corvette's are meant to be driven". This car is ready to drive - and enjoy the Tri Power. However if you want a show car it has the potential. Bottom edge of rear corners are perfect, wheel well edges are good and clean inside and out. The engine has been completely rebuilt bottom and top end - it was bored and new pistons rods resided and x-rayed - original crank polished - all new valves - roller rockers - new push rods - new cam lifters - timing chain - gears - oil pump - Engine assembly has been balanced. New hyd Crane Cam.
$39,900.00 USD
It is a 400HP with a M21.
Happy to send more pictures if need be.
604-566-0067
$39,900.00 USD
604-566-0067
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,358 Likes
Asking price provided by seller: $45,000.
