WTB: 68-69 Convertible, 4 speed
Hello, I'm new to the forum and am looking to buy a 68-69 convertible!
My must haves are:
4 Speed
Exterior-Red, yellow, or blue, no major flaws
Interior-Black or blue
Good Frame and Birdcage
Runs/drives well
My nice to haves are:
Small block preferred, but big block okay
Numbers matching block/transmission
Power steering
Vacuum system working for headlights/wiper door
Receipts/records/documentation
A/C (not that important)
The closer to Charlotte, NC, the better, but I will consider traveling.
I'm looking for something in the $20k-$40k range, depending on condition/options.
Thank you!
My must haves are:
4 Speed
Runs/drives well
Power steering
Thank you!
I'm considering selling my 69 coupe.
As for your criteria, here's what I've got...
My must haves are:
4 Speed
Exterior-Red - Not a perfect paint job, but it does look good
Interior-Black
Good Frame and Birdcage - No rust detected (I purchased the car in Sacramento CA)
Runs/drives well - Fires right up and drives (takes maybe 20s to crank if it sets for a couple weeks)
- Has small block
- Non original engine/never checked trans numbers
Power steering
- Yes, but the control valve leaks which is a common problem with that part
- Everything works
- I only have my receipts dated after I purchased the car
- No AC
- I live near Melbourne FL - Not very close, but not too far away either, probably about a 9hr drive
- I was thinking of asking somewhere around $18K
There are a couple of minor things to fix that i was going to work on when the weather cools off a bit.
- The passenger side window regulator is stripped where the handle clips on, so you have to fiddle with the handle to get the window up/down
- PS control valve leaks (common problem with these old cars) and if I was planning on keeping it, my plan was to upgrade to the Borgeson unit
- Reassemble some of the interior panels, all I need is to get the interior screw kit and put the aft panels back on.
In case you are wondering...
The reason I'm thinking of selling it is because I have my grandfather's recently restored 1970 C10 that is sitting in the driveway while the Vette is in the garage. I haven't driven the vette much lately and the only way to get the truck in the garage is to move the Vette out (which is not going to happen).
I'll see if I can post, or email you some pictures if you are interested.
My must haves are:
4 Speed
Interior-Black
- Has small block
Power steering
- Everything works
- No AC
