Patching a BFG Drag Radial - 1 day before race
Hi all,
Woke up this morning and saw that my driver side DR has a screw in it.
I've got a race coming up tomorrow, so I don't have time to buy a new tire.
My tread is really worn down, so I was planning on getting new tires anyway, but what should I do in the meantime for the Corvette Challenge tomorrow?
A) I figure if I bring it some place, they won't patch it because the tread is too low, is this correct, or do tire places not care about tread if you bring them racing tires?
B) Go to Advance Auto and buy one of those tire patching kits, and do my best to patch it myself... i'm thinking pull the screw out, jab that rubberized gunk in the hole, snip off the extra to make it flush, and then do a couple burnouts and see if it sticks/holds pressure
C) Realize I'm endangering myself and others, and either not race, or put street tires back on the car for tomorrow's race.
D) Call Roger and hope that he has some spare DR's hanging around for tomorrow Corvette Challenge...
Thoughts?
John
Thoughts?
John
Take the wheel with the tire off and bring it to a tire store and tell them that it's off a race car which is not driven on the street.
John
John
WalMart also has tire plug repair kits. It will work just fine.
Thanks for the replies.. I found a place that would patch it, drove it over there, and the screw was no longer in the tire... I was afraid to touch it before I got to a tire place in case I lost too much air, but apparently I must've just picked up a screw head, embedded 1/8th inch into the tire tread, and it popped out.
Tire pressure is stable, and no hole/leaks (no bubbles) so I guess I'm fine....
Still getting new tires next week though... just have to figure out if I get 275 or 315 BFG Drag Radials... I have 315's now, but with my stock car/stock rims, I wonder if the 275 size will be better for me...
If you are running the 315's on 11" rims, I would not drop to 275's..if you are presently running the 315's on a 9.5 or 10" rim then drop to the 275's for sure...
John
