Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Gear grabbing at the track *video*
Old 07-13-2014, 03:10 PM
dev1360
dev1360's Avatar
Default Gear grabbing at the track *video*
Thought I would share a video of my track outing the other night. Spent all night playing with tire pressures, and launches. Feeling out my (second, rebuilt) new clutch. DA was not very good, not expecting to set any records, just getting some passes.
Best times were 11.11@125 and 11.17@125. I had made a few changes to the car, and turned off the Wheel Hop Protection in the tune. I lost about 2-3MPH due to the air, but only lost a tenth with same DA, so I am happy and confident 10s are there. Still working towards low 1.6s and 1.5s.
Old 07-13-2014, 05:33 PM
dennis50nj
dennis50nj's Avatar
nice
Old 07-13-2014, 08:27 PM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
Nice job. I need to work on my 60' times for sure. What's your launch technique like? Can't really tell how much you may be slipping or dumping the clutch.
Old 07-13-2014, 08:38 PM
dev1360
dev1360's Avatar
Hold it about 4k, then stab the gas to the floor and feed out the clutch. Honestly like leaving a stoplight, just at 6k lol.
The video helped quite a bit, I didn't realize I was launching so low. I need more RPM on the launch. Between 6-7k.
Old 07-13-2014, 08:46 PM
sevinn
sevinn's Avatar
Thanks I'll give something like that a try. Maybe not so many rpms for me cause I don't want to break anything lol.
Old 07-13-2014, 08:59 PM
dev1360
dev1360's Avatar
These cars are pretty strong. That said, anything can always break lol. It sounds a little more brutal than it is. A strong clutch is a must because it takes the brunt of the heat and stress.
Bias plies have a much more aggressive clutch dump/slip. Radials require clutch slip because they don't like to be "shocked".
Old 07-14-2014, 01:06 AM
383vett
383vett's Avatar
Received 1,544 Likes on 1,044 Posts
Nice shifting and nice runs
Old 07-14-2014, 04:26 PM
Rob Petyo
Rob Petyo's Avatar
Nice runs!
Wouldn't you stick guys turn "on" the Wheel Hop Protection?
Old 07-14-2014, 04:27 PM
dev1360
dev1360's Avatar
Originally Posted by Hot_Wheels
Nice runs!
It was pulling 20* of timing in second gear picking up false wheel hop during the shifts.
Old 07-15-2014, 12:11 PM
Dr.Ron
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Nice going. Looks like you were logging?
Any idea of your shift times?
Ron
Old 07-15-2014, 02:01 PM
dev1360
dev1360's Avatar
No logging. Just checking IATs with my phone.
Old 07-16-2014, 06:50 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Nice shifting. That is a 10 second ride as is in better weather and with some launch refinement even in the summer.
You need to get rid of that bog. I launch higher than you and don't let the engine go below 4500 if you can help it in the launch technique. I get 1.4's pretty much at will by flooring the car when the tree is coming down and walking the clutch out.
Here is a secret RobZ taught me. Don't hold the car at RPM then release, be accelerating the car into the clutch release. I am at WOT before I release the clutch but you shouldn't start out like that.
I still have my OE clutch with 497 of these passes and 77,000 miles. So I've been doing this a time or two, I suggest you launch a bit lower than me and slip the clutch a bit more to eliminate that bog you are getting. That bog is killing your 60 foot.
Also, scan each and every run and analyze your launch RPM, time to WOT from first tire movement, and your shift times. You will learn a ton from analyzing each run. I certainly did.
Here's an in car video of one of my runs, you can see the launch rpm, where it bogs to, and where I'm shifting at.
Here is the scan of my run in my sig. You can see what RPM I launched at, note I was at WOT before the tires moved and note the car only bogs to 4700 or so, that was clutch fully released and WOT. Be careful with that, you might want to sneak up on it and not try that your first time.
Old 07-16-2014, 11:08 PM
dev1360
dev1360's Avatar
Thanks, Joe. I've watched your videos many times over lol.
The key for me right now is seat time. Leave higher, and ride the clutch just a bit more.
Old 07-17-2014, 08:16 AM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
No kidding. Thats cool.
Your next step is exactly correct. But do scan if you have HP Tuners (and it sounds like you do). If you scan your passes I'd be happy to give you my thoughts if you send me the log file.
Old 07-17-2014, 04:16 PM
RapidRick
RapidRick's Avatar
http://youtu.be/MyufsJIqa9I?list=UU8...ptPqrJdgAaxMZQ
Great advice. I've seen Joe's "1SicStik" - C6 launch like 100 times. It works!...
.....for a Daily Driver of course.
Dev, you'll be gettin' that technique down in no time gent. Great streetcar!
To Gear grabbing at the track *video*
Quick Reply: Gear grabbing at the track *video*
