Dart LS Next billit block
Old 01-15-2015, 02:48 PM
jcb5565
jcb5565's Avatar
Default Dart LS Next block build
Has anyone had any experience with this block? I'm thinking about building a new engine using the LS Next block and wanted to know how much boost these blocks can take? Any help would be welcome.
Old 01-22-2015, 06:00 PM
jcb5565
jcb5565's Avatar
Been looking at a lot of builds and none use the same manufactured parts. This engine should put out over a 1000 HP with a little boost. The good thing is the oiling system, The LS has a lot of problems with oiling and I have had enough of that problem. I'm going to go with the Callies crank H rods and diamond pistons. Heads have not be determined yet. Any advice would be welcome.
Old 02-07-2015, 02:14 AM
jcb5565
jcb5565's Avatar
No one knows anything about the Dart LS Next Block??
Old 02-07-2015, 11:30 AM
mr.beachcomber
mr.beachcomber's Avatar
Did a forum wide search on the DART LS Next block and didn't find anything of value (probably since this particular block is marketed primarily at pro drag racers). Your best bet may posting the same question on one of the LS1Tech forums. There are plenty of engine builders that frequent that forum. Hope this info helps.
Old 02-07-2015, 04:31 PM
jcb5565
jcb5565's Avatar
Its a rather new block and not much info.
Old 02-14-2015, 10:43 AM
jcb5565
jcb5565's Avatar
I have gathered enough information on the Dart LS Next Block, block is ordered and all the needed parts. Going to go for some big HP on this engine. I'll keep everyone up to date on the build.
Old 03-22-2015, 10:22 PM
Bad_AX
Bad_AX's Avatar
I'm researching this block for a C6 Z06 build, but not sure what solutions are available for the oil pan. What chassis are putting this block in?
Old 03-23-2015, 10:56 PM
FLTMEDIC
FLTMEDIC's Avatar
I'll let you know soon,Billy Briggs is building one with the mid sleeves for my car.
Old 03-24-2015, 07:59 AM
Bad_AX
Bad_AX's Avatar
It looks like ARE has a couple of dry sump pans for the Dart LS Next block.
http://www.drysump.com/ls-dart.htm
I can't find any information on the. I may call ARE today and see if I can get some info.
Old 03-24-2015, 10:43 AM
FLTMEDIC
FLTMEDIC's Avatar
So does canton the problem is they are not built for the ls7 dry sump set up.I have come down to running the moroso spacers and a stock pan.You have to use a remote filter due to how the oil system is on the block.
Old 03-26-2015, 03:38 AM
jcb5565
jcb5565's Avatar
The Dart LS next block is going into my C5. Oil pan has two solutions. the one I'm using is the adapters rail so I can use my stock Pan here is an example http://www.summitracing.com/search/b...version%20Kits
There are also custom pans being made for around 600.00.
Keep tuned as I continue on my build.
Old 03-26-2015, 06:35 AM
FLTMEDIC
FLTMEDIC's Avatar
There are several after market wet sump pans made,its the dry sump on the ls7 and the GS ls3 that there are really no aftermarket pans for.They make dry sump pans for the ls next but none of them for the stock type dry sump system.Canton makes a very nice wet sump pan if you don't want to use the moroso rail for your stock pan.
Old 03-29-2015, 03:00 AM
jcb5565
jcb5565's Avatar
Canton makes a dry sump pan.
Look Here https://www.cantonracingproducts.com...-DRY-SUMP-PAN/
Old 03-29-2015, 10:21 AM
FLTMEDIC
FLTMEDIC's Avatar
That pan is for an aftermarket dry sump system.It will not work with the factory Ls7 dry sump system.
Old 04-19-2015, 03:03 AM
jcb5565
jcb5565's Avatar
Have the block in for some machine work, honing the cylinders to size for the Diamond Pistons, checking deck height, checking the mains for proper fit. All new blocks should be checked before putting them together. Next I'm going to check my new heads valves to see if there seating properly and checking valve guide clearances. I'll give you more information as the project progresses.
Old 04-26-2015, 04:04 PM
BOUT X
Corvette Cowboy
Support Corvetteforum!
BOUT X's Avatar
Jim your going for big power I see who is checking your heads I need to find someone in our area to look at mine also I am not sure but I think my heads have a bad valve job on them. the landings on the angle are differant sizes and not flat I am in the middle of hand lapping and it doesn't look right.
Dale
Old 04-29-2015, 02:17 AM
jcb5565
jcb5565's Avatar
Dale
Dale give these guys a call they are highly regarded in the area.
Dynicron Cylinder Head Service
Today:8:30 am - 5:30 pm
Tomorrow:8:30 am - 5:30 pm
2817 N Cherryland Ave Ste 1,
Stockton, CA 95215
(209) 931-3230
To Dart LS Next billit block
Old 05-05-2015, 11:53 AM
Trackman101
Trackman101's Avatar
Just got my Dart LS aluminum block.
Post some pics and more info on your build please.
subscribed.
Old 05-12-2015, 02:39 PM
jcb5565
jcb5565's Avatar
My dart LS next Block is back from the machine shop, now the real work begins. All the parts are here now all I have to do is start the build.
The block before the machine shop.
Heads, six bolt.
More information and photos to follow.
Old 05-12-2015, 05:39 PM
Trackman101
Are you going to be using a hydraulic roller cam? Which oil pump did you choose? Will you be using oil restrictors?
Quick Reply: Dart LS Next billit block
