ZZ4 Harmonic balencer info & part number
Old 05-01-2015, 12:32 PM
StrayDog
Support Corvetteforum!
StrayDog's Avatar
Default ZZ4 Harmonic balencer info & part number
Hi , my friend has a ZZ4 in his C2, installed in his Corvette maybe back in 2007.
Wont idle goes between 600 / 800 very rough...when ignition turned off engine runs on ...the harmonic balencer appears to be loose
Can the balencer be tightemed & engine retimed ..or could the fact that
balencer was run loose , caused damage to rubber bushing ?
What is GM part number for balencer ?
Thank you, The Dog
Old 07-16-2015, 12:34 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
if the bolts are loose, tighten them, if the rubber is shot replace it. The part number is 19260269
Quick Reply: ZZ4 Harmonic balencer info & part number
