Paint/Body Corvette Materials, Techniques, and How To
Eastwood Concours HVLP spray gun ONLY 4CFM???
Old 06-24-2011, 09:41 PM
bryanpl123
bryanpl123's Avatar
Default Eastwood Concours HVLP spray gun ONLY 4CFM???
http://www.eastwood.com/review/produ.../category/211/
Does anyone have any experience with this gun? I understand that airflow is what aids in atomization of the paint, and I thought orange peel could be caused with a lower than recommended CFM flow... I know this gun is designed for 4 cfm, but is that really enough?
I am debating on this gun or something else..
I will be running my craftsman 33gal 6.3CFM(@40PSI) which this gun would work with.
I also have a T coupler and extra hose to hook up my Harbor freight 21gal (?7CFM?@40psi)
Together that would give me ~13.3CFM total to work with which should run most guns I have looked at, but I figured I should stay below this so that I do not risk inadequate air supply.
If you do not recommend the eastwood gun, what would you recommend given my current equipment capabilities?
I am a first timer, and will be practicing on a junk hood(many times), my brothers S-10(Black Metallic), and my buddy's 75 vette(Yellow Lacqure) before I Spray mine (undecided[blue/orange/green] metallic)... I really want an affordable gun that will aid in giving me the best results possible given my limited skills.
Thanks!
Old 07-02-2011, 09:45 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,638 Likes on 1,968 Posts
I have one but unfortunately I haven't used it yet. From what I read it is suppose to be a very good, solid gun - but not as good as some you might pay $4-500 for. I read a comparison test that said it was not quite as good at atomization of clearcoat as the highest quality guns but it was still very good. You might check in on the Eastwood forums and check out some of the experiences with it over there.
Old 07-03-2011, 12:03 AM
bryanpl123
bryanpl123's Avatar
I'll go over and check that out. Thanks for the response and if you get a chance to use it sooner than I do then let us know how you like it if you wouldn't mind, thanks
Old 11-19-2011, 05:59 PM
DansYellow66
I've used my Concours gun now. I'm not a spray gun expert so my opinion is pretty unimportant but I thought it worked well. I'm not sure about the 4 cfm rating though. It seemed to use quite a bit of air to keep it at or above 30 psi at the gun. I used it for single stage PPG paint. I suspect it didn't automize the paint as well as a more expensive gun would with a higher air demand.
Old 11-20-2011, 03:08 PM
bryanpl123
bryanpl123's Avatar
Thanks for the reply, i'm still up in the air on which gun to get since I'm doing a 2 stage job... but I probably won't be using the concours
Old 10-19-2016, 12:11 AM
Billy Nguyen
3rd Gear
Billy Nguyen's Avatar
Default It's not 4cfm.
The site clearly stated 6.5 cfm @ 30 psi. Reading these post people saying it's 4cfm pissed me off.
Old 10-19-2016, 06:03 PM
porchdog
porchdog's Avatar
iwata was one of the first low cfm guns at 9.5 . it's also 600 dollar. for an hvlp gun you need 100 psi at the wall to feed these guns . 3hp comp just wont cut it .
Old 10-21-2016, 06:47 PM
13611's Avatar
New member and already pissed off... that sucks. Don't get too mad at this 5 year old post you found.
Old 10-21-2016, 08:51 PM
Billy Nguyen
3rd Gear
Default It came up on the search engine that's the part I am pissed off about.
came
Old 10-23-2016, 08:04 AM
DansYellow66
Don't be pissed at me - I said years ago it seemed to use quite a bit of air to keep it at 30 psi - meaning more than the 4 cfm they claimed. I suspect Eastwood has admitted this now too and corrected their advertising to change 4 cfm to 6.5 cfm in recognition of this.
Old 10-23-2016, 05:26 PM
TWINRAY
TWINRAY's Avatar
6.5 is still way low for a real HVLP gun. I would expect to see at least a 12 cfm requirement.
Old 03-06-2021, 09:46 AM
Silent Shadow
1st Gear
Silent Shadow's Avatar
your talking about the eastwood concours pro which requires 6.5cfm@30psi. The concours 51550 uses 4cfm.
Get your facts straight before posting bogus information
Old 04-18-2021, 12:23 PM
John S 1961
John S 1961's Avatar
Dont you know at least half of everything on the internet is wrong. Beware of the "know it alls". Your results may vary!
Old 04-20-2021, 08:40 AM
Red86Z51
Red86Z51's Avatar
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
2021 --
It seems some newbie always manages to rediscover and unearth this thread every 5 years...and always with anger and conflict in mind.
To Eastwood Concours HVLP spray gun ONLY 4CFM???
Quick Reply: Eastwood Concours HVLP spray gun ONLY 4CFM???
