Paint/Body Corvette Materials, Techniques, and How To
Paint for aluminum wheels
Old 03-01-2015, 08:22 AM
jackson 63
jackson 63's Avatar
Default Paint for aluminum wheels
I would like to paint the aluminum aftermarket wheels on my Corvette. What type and brand of paint should I use. Or would powder coating be the way to go?
Old 03-01-2015, 06:01 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Powder coating would me choice. And a lot of it depends on the quality of the casting...if they are casted and then machined. Out gassing can occur and create small bubbles in the finish of the powder coating if the casting is porous.
Also...if you choose to paint them and you want the aluminum to show and not apply a color. Applying clear to the aluminum can possibly fail due to a lack of an adhesion promoter being applied which is either sprayed on and can discolor the aluminum or an applied acid etch prep for aluminum that does the same thing. If you paint them and them apply a clear...the clear need to be one that allows you to add a hardener to it.
I have seen guys who shoot them with 'rattle can' clear,,,and they look good for a short while..and then fail. A lot of that has to do with how much clear you apply to give it some body and thickness.
DUB
Quick Reply: Paint for aluminum wheels
