C5 Door Delaminated...Can it be fixed?
While replacing my outer door window seals I noticed a small movement or flex between the inner door panel and outer door skin in the area of the rear view mirror. I didn't have that movement on the passenger side. At one time the original owner did have bodywork done to the drivers door and I'm wondering if it being hit caused the delamination? My question is...
Can I somehow get a urethane adhesive into that area, clamp it up over night and be good to go ? The area in question is a raised "mounting boss" or platform that makes contact with the inside of the outer door skin.
I should have taken a photo while i had it apart so you guys can see what I'm referring to.....sorry !
DUB
