Paint/Body Corvette Materials, Techniques, and How To
Clearcoat application was going well then Murphy stopped by!
Old 10-16-2016, 10:33 AM
TWINRAY
TWINRAY's Avatar
Originally Posted by DUB
THANK YOU for the reply!
I truly hope all goes well and it lasts and lasts. I am not so worried about all of the amount of material on the hard top as much as I am the possible 'ring-out' effect that can show up later.
DUB
Do you mean the 3 feathered out spots might come through? Even with 3 coats of epoxy over them?
Old 10-16-2016, 05:54 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
YES!
Due to you breaking through the different layers of material....which all react differently to solvents. Once the clear coat has been sacrificed and sanded through...it reacts differently IN TIME than that of the base coat and so on. Which is why you can often times see the 'ring-out' effects in some repairs.
I do not care what is sprayed on the feathered out repairs that go all the way down or even partially down. Give it time. One day you might see a distortion in the area that was repaired. And sometimes it can be severe enough to actually disturb the metallics of the paint applied on top of it.
DUB
Old 10-26-2016, 12:57 PM
TWINRAY
TWINRAY's Avatar
Originally Posted by TWINRAY
I redid the top. Sanded with #220, 3 coats epoxy primer, blocked flat with #400 then #600, base + 5 coats of clear....
5 coats of clear, much of which I have just colorsanded off
Old 10-26-2016, 06:03 PM
DUB
DUB's Avatar
You should still ahve a bit of clear on the hard top. 5 coats of clear..if applied with a 'slow hand' is a LOT of clear.
I am sure this will buff out quite nicely.
DUB
Quick Reply: Clearcoat application was going well then Murphy stopped by!
