My first experience stripping
Thank you to the many forum members that gave advice, especially DUB. Did a small area with chemical stripper, too messy, will still have to sand many of the curves, but this sure helps get many layers of paint off fast.
get the area warm before you start . once you get the hang of it you can strip a door quick .
i actually heat the area then get it started so i can pull the paint off in big pieces.
This beats the heck out of dangerous, stinky, messy chemical stripper or ridiculous amounts of sanding. After we get those top layers off we are wet sanding with 180 to get primer off, down to fiberglass. I will have a few gouges to repair on the side I started on, before I got the hang of it. I ordered the Evercoat vette adhesive primer, thinking I will fill with that or would the rage extreme be better? Have both on the way.
Vette Panel Adhesive is a much better product in my opinion and it is all I use.. Rage Gold is much softer.
Do as you wish....but I would dry sand the primer off and not water sand it off.
FYIW...when you a have the primer exposed...do a small test spot with the stripper again and use lacquer thinner to get it off instead of water if that was what you were using. You might be amazed on how fast the primer will come off and you do not have to lay the chemical stripper in really thick...because all you are doing is removing a primer.....then sand of the primer and see if that will work for you. You might find that in your 'nooks and crannies' where it is about impossible to get the primer out...you might find that the chemical stripper is a very good method...or scrubbing with steel wool and lacquer thinner....because...those 'nook and crannies' are where paint and primer can likely lift due to it being hard to prep those areas.
DUB
DUB
