Mixing Bias Ply with Radial Question
I just got a set of 16inch Hoosier Quick time pros for the rears for the track and i have a set of radials up front. I want to make sure that I have this correct, If you mix these two on the track it could throw the car around pretty good correct? What option do i have to go with, im assuming getting another tire up front that is bias ply?? Jay
Received 2,054 Likes
Agreed the faster you go and less air pressure you run, the more wobbly they get. Call me crazy, but I still run the temp tires and have been 130mph on them, it's extended heat that's bad for them. Picked 'em up at a junkyard for $65 each, worth a tenth and mph in the 1/4 too.
I think this tire thing needs to be more specific. Its not so much of a radial front bias ply rear. Yes the bias ply rear tire does have more movement because of the soft sidewall. However if you run a skinny front wheel, GTO spares, CCW's, Bogarts,Welds you can have a 165r16 or so tire thats a radial and no wondering. Its typically when you run a bias ply in the rear and a big flat tire up front. The front stays planted and has more rolling resistance. This makes the rear want to wonder and come around or feel like it does. I personally ran bias ply skinnies up front and radials. My car car felt more stable with the skinny radials and from my findings trapped higher because I had less rolling resistance on those front tires IMO.
There you have it go beat the hell out of that car and make us C5'ers proud!
My personal experience was that I will never run full size tires up front if running a bias ply in the back. I almost wrecked my vette with ET streets out back and 245/17 radials up front. The car would swerve from side to side even tho you were holding the steering wheel perfectly still. Scary!
I agree you can mix radials and bias ply, but just always run a skinny up front.
back in the day...my old HCI Trans Am...et streets out back...stock fronts...not a fun ride...did bogarts with ET drags out back and skinny 165 r16 radials up front and it was straight as an arrow...on my vette did 26 11.5 17 et streets with GTO skinnies with MH racemasters on them and it was very stable the whole way down the track
Also had this ^^^^ happen to me when I had a Mustang with stockers on the front and slicks out back. Pretty scary to say the least.
