Build sheet location
can someone tell me where i can find my build sheet on my 04? i read someplace in here that its found in the front re-bar??? what would that be ?,, thanks rj
Check your glovebox.
redjetty, The build sheet is a folded printer sheet in the front crossmember frame rail (which is a hollow boxed member). I think the only way you can get to it is by removing the front fascia. An easier way to obtain one (albeit not "original") is to order one from the NCM. |
Originally Posted by wamara
What you are referring to in the glovebox is NOT the build sheet.
redjetty, The build sheet is a folded printer sheet in the front crossmember frame rail (which is a hollow boxed member). I think the only way you can get to it is by removing the front fascia. An easier way to obtain one (albeit not "original") is to order one from the NCM. You are correct, you have to remove the front fascia (bumper cover) and the front bumper (foam pad) then you reach in the end of the front impact bar (front frame cross section) and pull out the sheet. Anyone know how much the NCM charges for the sheet?:bigears |
:iagree:
You are correct, you have to remove the front fascia (bumper cover) and the front bumper (foam pad) then you reach in the end of the front impact bar (front frame cross section) and pull out the sheet. Anyone know how much the NCM charges for the sheet?:bigears Good luck... GUSTO |
i've got a thread on this, let me find it, have pics and location
here ya go, if you are local i'll help you remove the build sheet(takes about an hour)
http://forums.corvetteforum.com/show...highlight=ncrs http://i9.photobucket.com/albums/a96...uro/bap012.jpg |
