Bad ignition module symptoms
Just wondering what are the symptoms that a bad or damaged ignition module will cause? I have been getting code 42 meaning it could be the ignition module but my car still runs fine and strong, so im just curious. Thanks!!!
Hey Zeits - Get a load of this!!! 42 ICC code:rofl: :willy: :ack: :toetap: :eek: :smash: :crazy: :lol: :lolg:
Check this Island (pics for PCM by-pass): http://forums.corvetteforum.com/show...9&postcount=68 Read the whole thread; good pics and GOOD info... http://forums.corvetteforum.com/show....php?t=2069247 Your module alone can be tested at the Advance Zone any store. Zeits -we need to swap PCM's too, to see what happens. PM me if you wanna' try it. I can do without mine if you wanna' go first... |
Mine were hard starting, long cranking to start.
Mine began as car not starting when hot. Then one day in cruise it just quit.
Originally Posted by cfi
(Post 1566388423)
Mine always goes bye, bye after I shut the car off and try to start it up later. It can be overnight, or I can stop to get gas, but it never has stopped while running. This problem has happened in the original distributor and in an Accel distributor that I purchased to solve the problem. |
Originally Posted by jfb
(Post 1566388268)
A bad ICM is usually one of those "20 minute" type things. They tend to reveal themselves as bad when the car is hot.
....there is a long thread i started a few weeks ago dealing with ignition modules..take it from a guy who's replaced 8 of them!...in my case the car would simply not start...crank but no spark and no start....while there are symptoms of rough running at times that could be related to the ignition module due to heat, most of the time the ignition module will simply be either bad or good, period....
...no power to coil, bad coil, bad pick-up coil in distributor, bad ignition module, missing contact "button" on inside of cap can result in no start/spark... ...i don't believe that long cranking times have to do with the ignition module as i have that very same problem since i have owned my car...i have since replaced my capacitor/condenser assembly inside my distributor (1988) and am waiting to see how long my 8th module lasts.....what i would reccomend is that you change out the module and see what happens..at least you will have a spare to carry with you should yours go out while you are out.....good luck.... |
Hey Mail Man, thought you eliminated the Ignition module as the cuprit?
It'll start as hard starts; yes it'll take longer to turn over.
Then one day in the middle of traffic, with no warning, it will die and you'll be stuck there. It'll crank and crank forever and wont fire. So I'd go ahead and replace it, its cheap, but follow the electronic troubleshooting guides in the manual and make sure something else isnt bad too. |
Originally Posted by rick lambert
(Post 1566513132)
Originally Posted by vader86
(Post 1566513427)
Then one day in the middle of traffic, with no warning, it will die and you'll be stuck there. It'll crank and crank forever and wont fire. So I'd go ahead and replace it, its cheap, but follow the electronic troubleshooting guides in the manual and make sure something else isnt bad too. ........:iagree: |
(Post 1566513132)
Originally Posted by Stealthvette
(Post 1566629165)
My 86 needs a new IM every 6 months. It has never gone out while running. It always happens after I shut the car off and then try to restart or start it up first thing in the morning. I've replaced many, many in 9 years. Putting my system back to totally stock has not helped. Putting in a new distributor has not helped. So, I can eliminate the threads about the bad pick up coil, bad wiring harness and using aftermarket coils/MSD. Next??
My experience: Hot day-in traffic, starts to die, restarts about 3 times and then its over.
Originally Posted by Da Mail Man
(Post 1566629258)
....mine has never gone out while running either...it is when, after use, that it will crap out when i want to start it...i have over time and doing the usual tune ups and not throwing parts at it, have narrowed it down so far to be what i mentioned in an earlier threat here and again, only time will tell.....it is the ONLY part that i have either not tested or replaced....
(Post 1566629471)
As I recall you have tried changing your small wire harness inside the distributor. I hope that works for you. Unfortunately, I have replaced the whole distributor and still have the problem.
Stealthvette, when your ICM seemed to go bad did you take it into AutoZone or some other place to confirm it was bad? or just replaced it. If I were you 2 guys I'd also be checking connections on the ECM.
I think mailman replaced one of his ICM, then took it in and it checked out to be OK. Problem is, there is no way for US to check out the ICM, takes special equipment. |
(Post 1566637553)
(Post 1566637655)
...that is correct..i never took any of my icm's (8 or 9) in to be tested as they were all under warranty..i DID take the last ac delco TWICE and the first time ran it through 3x's and it tested good..the second time i ran it through +/- 15x's and it also tested good...i DID however a long time ago, cleaned and checked all the connections to/from the icm....
