thanks
Here's a vid I made how to do it cheap and links to cheap supplies
that would be great but i see no pics
Originally Posted by Virgil Clinton
(Post 1601794084)
Welcome to the forum. :cheers: |
Originally Posted by Leonardo111
(Post 1597869712)
bonjour de France Didou |
Back up cables
Originally Posted by ottawabarber
(Post 1570972259)
My hood release cable has worked fine since I bought my 88' but many threads here have mentioned horror stories of a broken cable and not being able to get the hood open.
One great solution that has been discussed here was a set of emergency release cables in the wipers area. I decided to make a pair for mine and thought I would take some photo's to share for people like me who find a photo or drawing often times more understandable than only words. Total cost was $7.00 !! 1/16" wire cable at .69 cents a foot, and one package of Cable Clamps and Stops and state tax. The clamps are aluminum and need to be hit with a hammer against a steel bar to crimp the cable properly. Here is the location of the existing factory installed cable. Adjacent to the cable connection is a small opening that allows the 1/16" cable to go through. http://starvedrockcorvettes.com/clampSU.jpg This next one is a close up of the clamps I used. http://starvedrockcorvettes.com/clampB.jpg Since I was using 1/16 cable I decided to drill a 1/8" hole through the rubber guard below the wipers to allow free movement. I tried to make the cable lay as straight as possible. This photo is the cable before being cut and the stop being put on. http://starvedrockcorvettes.com/clamp4.jpg These next two photo's show the cables completed, and the last is a close up of the connection. I intend to paint them black to make them blend in and not be so noticable. Total time 30 minutes (a guy has to sip some malt beverage on a job like this :cheers: ) I now have a great piece of mind knowing if my primary cable fails, I can still gain access to the underhood to fix it. http://starvedrockcorvettes.com/clamp3.jpg http://starvedrockcorvettes.com/clamp8.jpg http://starvedrockcorvettes.com/clamp9.jpg Hope this is helpful for some of you :flag: :cheers: Larry where are the pics?? |
Originally Posted by Whrabbit
(Post 1604863066)
1 Attachment(s)
These are easy to make! I used picture hanger wire so it did not show as much and was still strong. I also put some Lithium Grease on the latch. ::cool:
Here is a Screenshot from the above video. |
