Cog Drive pros vs. cons/ LS6 Blower question
Would any and all F/I experienced members (who know about cog drive set ups) please give me a little direction, and your 2 cents on using a belt Cog drive set up with a Centri blower?
*I know cog set ups are whiney, but that is what I want. Question: #1. Is there a minimun PSI you have to be running to optimize cog set ups? Question #2. You hear of regular belts spinning or throwing often, doesn't the cog set up hold better overall? And if so, why don't you see more F/I guys with Centri blowers running a cog set up? They make various widths of the cog belts and pulleys right? I am stewing over some ideas for my C5Z, the "Silver Fox". Enginewize she has heads, cam, but on stock LS6 bottom. Ported LS6 intake, TB, Headers, Borla Stinger CB. Had it a while, and I am getting bored now. Just need more power you know!... These new cars can get your spirits down, mine anyways... LS3 Vette's, C6Z's, the C6ZR1. All these cars just lick their chops when they see a C5, that hurts a man. An LS3 C6 gets a cam and 500 to the tires, crazy.. It's hard to compete with that in a bolt on H/C N/A LS6. (Driver obviously makes A difference) My ultimate goal: Big cube 427/434/444, supercharged, cog drive nestled in my 2003 C5Z.. 800 RW horse (Really peak # not important as long as it is alot of power and and stays up there for a large portion of the powerband). Drivetrain obviously being a priority at this level.. Question #3 But in the meantime while I work out the motor build, I want to get the supercharger installed now and put it on the LS6. Im not planning on beating on it, but I do want to enjoy it, car needs to streach its legs now and then..And I'll also get use to driving a SC car while motor is being built. Is this a good idea or not, and why? I was thinking nothing major on boost, but I did want cog pulleys.. Question # 4 If possible, I also want the ability to run standard boost levels on the stock LS6, but then the ability to crank up the boost on the built motor. Any suggestions on what Vortech or Procharger head unit fits this profile? please chime in. Your input is greatly appreciated. Thanks JB |
seeing that you're in dallas I'm going to recommend you get in touch with Bret (blownbluez06)... he can help you out with anything you need, give you a great tune, and he's local to boot:thumbs:
(Post 1587432862)
1.GD setups for the vetts that are out are junk..period.. I know first hand of coarse
2.You can make 800 on a p1sc1 and stock CI motor..and be reliable and be faster then any of the combos you stated 3. An over spun smaller head unit is twice as fast as an under spun bigger blower.. You need to really read..preferably on some of the outlaw/grudge racing sites on how blowers work and why. If you get 100% of your info here, you probably going to get a lot of BS and be just as slow and disappointing the rest of them here. |
i have a House of Boost/Procharger cog setup for sale on the cheap if you are interested.
Originally Posted by joshtownsend
(Post 1587433317)
(Post 1587433317)
(This is sometimes my Internet attitude but I hope this can be understood with a smile. In fact, I already apologize. Sorry Josh if this is too aggressive reply.) Please Josh: do not generalize with GD. I know personally that it can be done - and it has be done. But not necessarily by just reading these forums.. For the OP: forget the GD. You won't need it. Go with 8 or 10 rib; ask from your supercharger vendor more info and you'll be fine. |
Originally Posted by Pekka_Perkeles
(Post 1587434647)
True. You failed.
If 800whp is your goal you dont need a engine nearly that big.. Start looking at somthing from 364-408ci, they will easily make over 900whp with a conservative tune up. Look at head Units like the Vortech YSI, Paxton Novi 2200R with a 10 rib drive. It makes NO sense to go through the cog drive hassle at that power level. Plenty of guys running 10 rib over 1000hp with no issues.
Originally Posted by breecher_7
(Post 1587434801)
JB |
Originally Posted by robert miller
(Post 1587434754)
:iagree: Good 8 rib with a flip drive with everything set up correct will get ZERO slip on the unit. Robert
I think you guys are slowly swaying me away from the Cog setup. JB |
(Post 1587434801)
I also agree on the smaller C.I motor also if I had it to do over would have went smaller C.I. Robert |
(Post 1587435819)
:crazy2::crazy2: 8 rib here with over that in rwhp plus with ZERO belt slip. But do have flip drive set up on it. Befor the flip drive YES on the belt slip...
I also agree on the smaller C.I motor also if I had it to do over would have went smaller C.I. Robert Yeah a 8 rib with DD will be fine on a YSI/2200R with a 3" or larger pulley. Below that it slips from my experience. |
