Originally Posted by red 1
(Post 1592301138)
Nothing to wire except positive and negative 12 volts , everything else just plugs in
Originally Posted by StingRaycer
(Post 1594460522)
could you tell me where you wired the unit for positive?
I bought a micro add a fuse tap at Autozone and plugged it into the front fuse box fuse that is labled ignition even so it only powers up when the car is powered on. I crimped the positive wire to the add a tap and grounded the negative side to the ground bolt on the frame rail just in front of the fuse box. |
another fuse to plug into
(Post 1594461132)
Originally Posted by kennedyd
(Post 1592301370)
Anyone know if this would work on android phones? Seems like a cheap alternative but the seller's listing doesnt seem to provide any info,
Features: 100% brand new and high quality. ***Wifi Transmission, support for iPhone, for iPad and for Android phone.*** Adjustable multiple angle camera viewing,with image-flip ability. Camera & transmitter rainproof, dustproof and shockproof. Minimum illumination less than 0.5 Lux, digital compensation for clear night vision. Easy installation, wiring free. 12V-30V DC car power supply. Transmission distance without obstacle will be more than 150 meters. ***The client terminal shall support for Android 2.2 or above,and for IOS shall support Version 4.3 or above.*** |
Originally Posted by syswayne
(Post 1594566582)
I know you said to plug in the even #28 on my fuse box, and I did and this all works well. I just wanted to know if there was another fuse I can tap into without starting the motor. Did not want to take a chance of trying everyone of the fuses did not wan to blow on. Just t thought you might know of one. I followed your instructions and it was great. Thank you and hope you can reply syswayne
Reverse camera display
[QUOTE=red 1;1592290858]Just bought this wifi wireless unit and camera that displays on my Iphone for $38.00, not 1080hd but good enough to not ruin front bumper and new splitter.
https://cimg3.ibsrv.net/gimg/www.cor...8887743e46.jpg I bought the same kit as pictured, with the same camera, how do I change the display to forward looking? |
[quote=JVervaecke;1594600852]
(Post 1592290858)
https://cimg3.ibsrv.net/gimg/www.cor...8887743e46.jpg I bought the same kit as pictured, with the same camera, how do I change the display to forward looking? The camera sells for about $15.00. I would also purchase a RCA Video Coupler and RCA DC Power Audio Video AV Extension Cable. It will give you a lot more distance to be able to mount the WiFi Box. Here are the links to these items. If you run into any more questions post them here or PM me. |
Originally Posted by zbrett
(Post 1592377779)
Due to the potential issues with this sealed camera (I don't mind the guidelines but I do not want the view reversed), I ordered a different one from Amazon. You can make all the adjustments outside the camera with by clicking one button.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I should have it tomorrow. Even with the cost for the additional camera, it is still a great deal compared to the other bundles out there. |
Originally Posted by drivemewilder
(Post 1594619484)
I've added to cart the camera, the extra length wire, and the female to female jacks that you suggested. I still need the wifi box correct? Where can I find it?
WishRing Wifi Car Backup Camera Realtime Video Transmitter for iPhone HTC Android 903W |
what was the amperage for the micro fuse tap?
thanks charlie
(Post 1592313392)
The unit only weighs about an ounce so I wire tied it to the radiator over flow tube right beside the passenger side of the radiator.
Originally Posted by cberistain
(Post 1594621554)
thanks charlie |
(Post 1594622786)
I think I used a 15 amp
https://cimg8.ibsrv.net/gimg/www.cor...dc25f9b3ce.jpg |
(Post 1594629599)
(Post 1594631026)
Buttons as far as I know are not covered.
(Post 1594629599)
Note: The tape is built up so the shrunk- shrink wrap will not press on the button. I also put shrink wrap over the yellow video and red power connectors, once connected, to protect the connections from water and make sure they do not come apart.. |
1 Attachment(s)
Half of my order came in today, camera and wifi box. Still waiting on extension jacks and female to female couplers. Left side of photo shows DC in with tiny gauge wires (red and black). Is this what goes to fuse box? What do I need to make that connection? Then you can see the red/yellow jacks from box to camera. This is where the extension will go once it gets delivered. Why did I need to purchase the female couplers? Do i not have everything lined up correctly?
(Post 1594632940)
(Post 1594632940)
https://cimg1.ibsrv.net/gimg/www.cor...5f42cc465e.jpg Used the Micro Fuse Tap to the Ignition Even Fuse. This insures that the camera is only on when the car is running. https://cimg5.ibsrv.net/gimg/www.cor...3ae18f16d6.jpg Cut a small slit in the fuse using a Dremel to prevent the wire from getting pinched. Taped all the connections together to keep them from pulling apart https://cimg8.ibsrv.net/gimg/www.cor...2c3e638217.jpg Used a small nut to prevent the camera adjustment button and them covered with vinyl tape to waterproofed the Camera Adjustment Box https://cimg1.ibsrv.net/gimg/www.cor...10854d3a44.jpg Taped all the connections together to keep them from pulling apart |
(Post 1594621554)
thanks charlie |
