Another reason the stock DS can't be used is because the RG's output shaft has 32 splines vs. 27 for OEM and I can't find a 27 spline slip yoke w/ 1310+1310 U joints. If there's one, then I'd go for that but it will have to be a quick release type. So our choices are very limited.
Originally Posted by BruZe06
(Post 1594111459)
http://www.dennysdriveshaft.com/p10_...series_32.html http://www.dennysdriveshaft.com/p464..._series_g.html Tom |
Tom's solution would definitely work for you. I know a lot of people here have run the combo joint, even on the transmission end, to use the stock driveshaft. I think that is what all the TKO conversions run, and used with some high hp engines. Those transmissions run so far back into the tunnel that in some cars the 1330's don't even fit.
Bill |
Originally Posted by Sky65
(Post 1594111512)
Use a Corvette T400 yoke at the trans end. 32 spline, bolt on 1330 u-joint. Then use a combination u-joint to the stock shaft. The u-joint I listed has a grease fiting just as a sample joint.You want a solid joint and Spicer makes them.
http://www.dennysdriveshaft.com/p10_...series_32.html http://www.dennysdriveshaft.com/p464..._series_g.html Tom All you guys' responses have been helpful and I much appreciate all the advises and insights. |
