Don't wait till you scrape! Check this out!
Old 01-11-2013, 12:34 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Don't wait till you scrape! Check this out!
Hi Everyone!
C5/C6/ C7 Corvette owners know that the front skid plates are vulnerable to getting bumped and scraped. Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6 / C7 Corvette. Made of a High Impact Superior Performance Plastic, the C5/C6/ C7 Fangs are extremely impact resistant and 6 times more abrasion resistant than steel and Installation only takes a few minutes. Being only 1/8" thick you will not even notice any clearance loss. There is NO drilling or modification required! C5 Fangs are a simple 10 minute bolt on using your factory bolts.C6, you simply glue them on or if you prefer, they can be screwed if you order the screw on kit. It comes with drill bit and tapping screws. Once the Fangs are installed you will have the best protection available. $49.99 is a very small price to pay for such good protection of such an expensive part of your Vette!
(Note: we still have the screw on C6 Fangs for those who prefer them. Check our website)
Some of the Benefits
1) They are only 1/8” thick so there is no noticeable ground clearance loss. That’s very important since there is not much clearance there to begin with!
2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
3)They perform perfectly in hot or cold weather.
4) They distribute the load over the entire skid plate where it is the strongest and can evenly distributes the impact, not on one side or the other where the side load can bend skid plate.
5)There are no moving parts to wear out.
6)They only weigh 5oz for those that worry about weight.
7)There is no drilling or modification needed to install them
8)The Fangs give protection over the entire skid plate. So if you bump up on a parking block like we demonstrate in our video you are protected from the front to back and from the highest point of the skid plate to the lowest.
9)They look like something that came on your Vette from the factory.
Here is a video of the Fangs getting used!
http://www.saccitycorvette.com/See-t...n-Action-.html
Here is info for the C5 Fangs
http://www.saccitycorvette.com/Fangs.html
Info for the C6 Fangs (Note: we still have the Screw on C6 Fangs for those who prefer them. Check our website)
http://www.saccitycorvette.com/C6-Fangs.html
Info for the C7 Fangs $66.95
http://www.saccitycorvette.com/C7Fangs.html
C6 Glue Fangs
C6 Screw On Fangs
Fangs will help prevent this from happening.
No gluing for the C5 Fangs. They bolt on with factory bolts.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 01-17-2013, 02:29 PM
SacCityCorvette
Supporting Vendor
Fangs only take a few minutes to install!
Old 01-22-2013, 03:09 AM
SacCityCorvette
Supporting Vendor
Fangs are a worth while investment for your C5 or C6 Corvette!
Old 02-09-2013, 08:34 PM
raspyc6
raspyc6's Avatar
I'LL bet my OEM "fangs" look beat to hell. GLWS.
Old 02-09-2013, 08:47 PM
ZO ZICK
ZO ZICK's Avatar
nice
Old 02-09-2013, 09:00 PM
vettelover69
vettelover69's Avatar
Do these really work?
Old 02-09-2013, 09:52 PM
EVRose
EVRose's Avatar
Did you see the video of a C6 driving up onto a curb? That should answer your question and is what convinced me.
Old 02-10-2013, 05:30 PM
SacCityCorvette
Supporting Vendor
vettelover69, here is a pole that someone took recently.
http://forums.corvetteforum.com/c5-g...-are-poll.html
Old 02-15-2013, 05:13 AM
obxchartercaptain
obxchartercaptain's Avatar
FL Events Coordinator
I think if you run up on a parking stop or a steep driveway or a culvert they would work. But the problem I have had...ONLY ONCE was the support for the radiator seperated at the weld on the lower support which required replacing it. I do not think the fangs would have stopped that.
Old 02-21-2013, 08:55 PM
TerryL
TerryL's Avatar
St. Jude Donor '17
Originally Posted by SacCityCorvette
Why wait till you scrape?
Well since you asked, I don't see as how your slip cover would prevent any damage to anything other than what it's covering. Certainly it won't do any more 'good' than the OEM part it's covering right?
Old 02-21-2013, 11:02 PM
l8-apex
l8-apex's Avatar
I would normally agree, but these are working well for me. I have a steeply sloping driveway with a shallow gutter at the entrance. No matter what kind of angles I use I seem to drag at least one of the skid bars every time I enter or exit. The aluminum skid bars would have worn through pretty quickly, and they were also marking up my concrete pretty badly. I put on some of the plastic covers (glue-on type) and they slide nicely when I drag the concrete (leaving no marks). They seem to be pretty tough and should last a long time. I'm happy with them. Maybe when they wear down SacCity will give me a discount on the next set??
Old 02-27-2013, 07:09 PM
SacCityCorvette
Supporting Vendor
Hi Terry,
They do help prevent damage by just sliding instead of the metal grabbing traction and breaking the support. Believe me, we have tested this theory.
Old 02-27-2013, 09:01 PM
TerryL
TerryL's Avatar
St. Jude Donor '17
Hi Terry,
If you could post a pic of them after they've scraped a few times, it might be a good selling point.
Old 03-01-2013, 06:53 PM
SacCityCorvette
Supporting Vendor
Ok, we will work on that!
Old 03-25-2013, 01:10 PM
kfede1
kfede1's Avatar
Default So do they fit or apply to a grand Sport?
I saw the video, The skid bar was removed from the car. Is that a requirement? Do they fit a 2014 Grand Sport?
OlyC6 (04-09-2016)
Old 03-25-2013, 01:45 PM
SacCityCorvette
Supporting Vendor
Hi kfede1,
We used a skid bar out of the car just for better visual. Its a simple install on the car.
Yes they fit the 2014 GS but may not be necessary since the splitter will probably hit first. We have a few customer that installed Fangs as a precautionary.
Thanks,
Christian
Old 03-27-2013, 09:32 PM
thehueg
thehueg's Avatar
$50 for two pieces of plastic? Seems like the Vette front end isn't the only thing getting gouged.
To Don't wait till you scrape! Check this out!
Old 03-27-2013, 10:18 PM
RHFD122
RHFD122's Avatar
ttt
Which is best in the long run, the glue on or the screw type that you need to DRILL TWO HOLES?
Old 03-28-2013, 12:50 PM
SacCityCorvette
Supporting Vendor
Originally Posted by RHFD122
ttt
Hi RHFD122
They both work the same. Some Vette owners just didn't want to drill so we came up with a alternative.With the glue on Fangs, just make sure you get the quick ties nice and tight while the glue dries.Then cut the quick ties off.
Thanks
Christian
Old 04-13-2013, 03:14 PM
donzi1
donzi1's Avatar
I screwed mine on. Old school peace of mind...Ed
Quick Reply: Don't wait till you scrape! Check this out!
