New radio
Received 19,305 Likes
'20-'21-'22-'23-'24
That looks really good - perfect fit. And I like the faceplate.
Location: Blessed are the cracked. For they are the ones who let in the light.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Looks fantastic...love it..
I am from Pa...I can listen to anything.
Buy my radios from Crutchfield. They have good customer and tech support. If you use a bypass harness you can keep your Boss speakers. That's what I did. It rocks!
If you go to Crutchfield site put in vehicle info, it will list all the head units that will fit and the bypass kit you will need. Just call them with any questions. Everyone one ever talked to seemed very knowledgeable
Rob 02 (07-28-2016)
https://www.corvetteforum.com/forums...-question.html
OP - Looks good!!! Enjoy!
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Enjoy the sounds!
The 2 most common adapters are:
1) Axxess XSVI-2004
2) Pac Audio ROEM-VET1
Replacing the head unit should be just plug-and-play by using either one. Both have setup adjustments to customize sound/levels. After tweaking them to your liking, they shouldn't require further touching.
Rob 02 (07-28-2016)
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Looks good, enjoy your new tunes (but country? lol)
