Oil temp 234
Oil temp 234
Did a brief,120 mph.Maybe 4-5 miles.
When I stopped,oil temp was 234,and the oil pressure,dropped to,27 lbs. just drive home easy.oil temp.dropped to 204 deg,oil pressure 32 lbs. am I ok? Oil is full,and thought,I smelled a little burnt oil.no sight of leaks. Think I'm ok?
Received 2,708 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
234 degrees, you'll be fine
Received 19,309 Likes
'20-'21-'22-'23-'24
You're car is fine with that temp.
Thanks guys you've made me feel better.was a little worried,don't normally run her like that.It was that damn! Rt chargers fault! He started it! I just finished it!.
Received 1,261 Likes
4-5 miles at 120+ is brief?
Received 1,679 Likes
That's heat soak for ya! Pretty normal. Your hot oil pressure is fine. I wouldn't worry about oil pressure until you drop way low - or unless you're doing extended high-G turns (road racing). Idle at 32 psi is normal too.
maybe you should mod the car so it doesn't take that long to handle an rt charger
Forcedvert (09-01-2016)
Sorry but your math is wrong. At 120 mph, one would travel only 2 miles in 1 minute. If the OP traveled 4 - 5 miles as he said he did, it would take him 2 - 2.5 minutes to travel that distance at that speed.
BTW in order to cover 4 - 5 miles in 1 minute, one would have to be doing a sustained 240 -300 mph. I seriously doubt there's a (street legal) C5 in existence (or ever was one) that can (or could) go that fast.
