click, click goes a relay.....
Old Aug 29, 2016 | 03:48 PM
Doug34's Avatar
Doug34
Default click, click goes a relay.....
not used to all the electronics in these newer corvettes, every time I walk close to my C 5 I hear a relay clicking, no light flashing, nothing, both key fobs are set to "off" , I just changed both batterys in my key fobs so I feel this is a "self inflicted " problem. Thanks for any help rendered, DOUG
Old Aug 29, 2016 | 03:52 PM
gimp's Avatar
gimp
Do you have the option to auto unlock the car as you walk up to it?
Old Aug 29, 2016 | 04:28 PM
FX VETTE's Avatar
FX VETTE
Originally Posted by thisMSGgood4me
I didn't know that was an option on any C5's. How do you turn that option on?
Old Aug 29, 2016 | 04:33 PM
kpcets's Avatar
kpcets
Veteran: National Guard
I believe they are referring to the passive switch on the key fob. If my memory is correct this was available 97-99, 200 and up didn't have this option.
Also when he mention that both fobs are set to off I thought this is what he was referring to. If that is the case you might just want to make sure and switch them on and off again.
Old Aug 29, 2016 | 11:08 PM
Doug34's Avatar
Doug34
I have turned that passive feature on and off with no change,thanks for the reply, still looking
Old Aug 30, 2016 | 03:34 AM
buckeye1872's Avatar
buckeye1872
Does your horn normally beep when you lock your doors with fob? That would narrow it down if your passive feature is causing the clicking noise (doors locking/unlocking). I had that issue when I first got my car. I cleaned the contacts inside the fobs for the passive feature and resolved my issue. And since you replaced batteries in the fob did your relearn them through the DIC. Post #11 will explain that if you have not. https://www.corvetteforum.com/forums...m-key-fob.html
Old Sep 1, 2016 | 11:01 PM
Doug34's Avatar
Doug34
Default clicking relay
Thanks Buckeye, You saved me some grief, thanks again for your time DOUG
Old Sep 1, 2016 | 11:22 PM
buckeye1872
To click, click goes a relay.....
