M20 TO M22 and new clutch
Old 08-28-2016, 06:01 PM
Kryptonite
Kryptonite's Avatar
Default M20 TO M22 and new clutch
Rebuilt Muncie M20 to M22 all new guts also New 75224 Mcleod Clutch as suggested by Lars.
What differences will I see now? will there be a BREAK IN period anything I should do or change once its back together? Coupe has 383 stroker engine maybe 40k 400+ hp the rear gears 336 with full headers and sidepipes Hookers. Also do I need to reinstall the lock out cable it was already unhooked from the column. Thanks its the red coupe
Old 08-28-2016, 08:23 PM
ddawson
ddawson's Avatar
My new M22. I was told 500 miles then change the oil. 1st gear was a little hard to slip in unless you were moving. It slowly got better as it wore in.
It's great now after the oil change.
Old 08-28-2016, 10:05 PM
Kryptonite
Kryptonite's Avatar
Default input shaft
which one did you have 23 or 10 and what are your gears 336
Old 08-29-2016, 12:17 AM
ddawson
ddawson's Avatar
10 with 336 gears
Old 08-29-2016, 02:55 PM
Kryptonite
Kryptonite's Avatar
Default M20
Is it quick out of the gate? m20 1st gear is different from m22
Old 08-29-2016, 02:57 PM
redvetracr
redvetracr's Avatar
what is a "23" ??
Old 08-29-2016, 04:11 PM
Kryptonite
Kryptonite's Avatar
Default spline
Originally Posted by redvetracr
what is a "23" ??
we were discussing the spline
Old 08-29-2016, 06:14 PM
redvetracr
redvetracr's Avatar
I assumed so but there is no 23 spline
Old 08-29-2016, 07:38 PM
Kryptonite
Kryptonite's Avatar
26 whoops
Old 08-29-2016, 09:09 PM
Big Block Dave
Big Block Dave's Avatar
If you like downshifting from 4th to 3rd, for passing gear on the highway, you will love this combo..... however, Id rather have the 2.52 1st gear of the M20.
The mcleod super street pro uses the same pressure plate as the street pro, which I have used. Pedal feel is basically same as stock, and Im a fan of it. FWIW, Im in the midst of a motor and trans swap, and the 26 spline version of your clutch is what Im putting in.
Lockout cable not required. Have fun.
To M20 TO M22 and new clutch
Quick Reply: M20 TO M22 and new clutch
