NPP on C7
Old 08-30-2016, 12:34 PM
maxp
maxp's Avatar
Default NPP on C7
I know this has probably been asked before but numerous searches have not produced anything: can the NPP exhaust on the C7 be opened/closed like on the C6 with a M2W switch? (On my previous C6's I would have the exhaust open about 90% of the time). I have checked the C7 operational and infotainment manuals but don't see anything about exhaust control.
Thanks for any feedback.
Old 08-30-2016, 01:46 PM
Boiler_81
Boiler_81's Avatar
The best thread on the C7 NPP exhaust system. The information is factual and up to date. https://www.corvetteforum.com/forums...ck-result.html
maxp (08-30-2016)
Old 08-30-2016, 01:58 PM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
There's no need for a mild to wild switch. Sound management is handled by the selector switch, so going from tour to sport or track will change the exhaust sound. You can also set it up to operate independent of the drive mode if you want to run in say track sound all the time.
maxp (08-30-2016)
Old 08-30-2016, 03:31 PM
Kevin Schneider
3rd Gear
Kevin Schneider's Avatar
How do you set the exhaust to be open all the time on a C7 Z06?
Old 08-30-2016, 03:36 PM
Foosh
Foosh's Avatar
Received 16,669 Likes on 8,312 Posts
It's in the settings menu on the center screen. The choices are "mode dependent," which means open in Sport or Track, or "off" which means always open.
The following 2 users liked this post by Foosh:
Coach Yocs (08-30-2016), maxp (08-30-2016)
Old 08-30-2016, 03:43 PM
Boiler_81
Boiler_81's Avatar
In order to meet Federal Drive by noise standards, the valves close even in track mode. The only way to keep them open is to pull the fuse or wire in one of the solutions outlined in the thread previously referenced.
I pulled the fuse and just leave it open at all times. If I were going on a long drive and want to tone it down, I would pop the fuse back in and control the exhaust from the cabin.
I recommend you start with just using the control in the car. Some people don't notice the valves closing for the Federal test parameters. If you hear the "hitch" and it bothers you, do the fuse pull or wire in one of the solutions.
maxp (08-30-2016)
Old 08-30-2016, 03:52 PM
Foosh
Foosh's Avatar
I know I've read they close "sometimes," but I sure don't notice it in street driving. Thus, I've seen no need to pull the fuse. My setting selection is always "off" which means almost always open. :-)
Coach Yocs (08-30-2016), Kevin Schneider (08-30-2016)
Old 08-30-2016, 04:01 PM
Boiler_81
Boiler_81's Avatar
Like I said, some people notice it others don't. It may be a difference in driving style, hearing or something else. I certainly noticed it and it bugged me. Therefore I pulled the fuse.
From the previously linked thread:
"UPDATE 9/30/2015: I had the opportunity (surreal quite frankly) to meet Tadge and Harlan at a private event today. I spoke privately with the two of them for about 10 minutes, and one of my questions was the NPP programming. Tadge's comment was something like "If we didn't do it that way, we wouldn't be legal". Meaning that even in Track mode, the valves need to close for the dB requirements in the FMVSS pass-by noise regulations.
meyerweb (in post #252 in this thread) figured all this out a while back and is 100% correct that the NPP programming is architected around the FMVSS pass-by noise regulations.
https://www.corvetteforum.com/forums/...post1589760867"
maxp (08-30-2016)
Old 08-30-2016, 04:08 PM
UsernameProtected
UsernameProtected's Avatar
I'm just a control freak, so I wired the relay in so I can control it wirelessly with the Homelink visor. Love it this way.
Old 08-30-2016, 04:26 PM
Foosh
Foosh's Avatar
I don't think it's my driving style that causes me not to notice it. I do spend a lot of time in the upper rev ranges, but our streets are so rough I'm often in Tour mode w/MSRC on the street w/ the valves open. My best 50-mile fuel economy average is 20.1 mpg. On our smoother roads, I do use Sport as well.
I suppose I should pull the fuse to see it there's a difference, but have always been plenty happy w/ the engine music.
Old 08-30-2016, 04:29 PM
Dif
Support Corvetteforum!
Dif's Avatar
that thread explains EVERYTHING
Old 08-30-2016, 04:39 PM
maxp
maxp's Avatar
Thanks, this is exactly the information I was looking for.
Old 08-30-2016, 04:41 PM
joemosfet
joemosfet's Avatar
DashControl unit plugs into ODB2 port, allows you to show any pids on the dash, set up shift alarms, etc, and gives the ability to override the NPP functionality for true always-open or always-closed functionality by using the mirror selector switch. (L = always open, R = always closed, Middle = let the car decide.)
Old 08-30-2016, 05:15 PM
Boiler_81
Boiler_81's Avatar
I would be interested in what you find. There have been several threads on NPP. In them there are people who are adamant they can't hear a difference and then there are those who like me who can clearly hear the "hitch".
Old 09-07-2016, 10:17 AM
long_tall_texan
long_tall_texan's Avatar
Great thread. Thanks for all the info. I have a non-electronics related NPP question. Has anyone dissected a C7 NPP muffler? Wondering what the inlet and outlet diameters are. Also wondering if the "open" side is a perforated tube like most C6 NPP or if it is a solid tube like C6 ZR1 and 12-13 NPP.
I'm curious, because I've been considering a C6 ZR1 exhaust swap on my 2007 Z06. But I ran across a smoking deal on C7 Z06 mufflers. I don't think I'd have much trouble manually wiring an open/close M2W type switch to actuate the butterfly valve on the C7 mufflers. Just curious if anyone has tried that yet.
and yes, i did search, but found nothing... If I missed it, please direct me. TIA for any insights.
To NPP on C7
Quick Reply: NPP on C7
