LT4 High Pressure Fuel Pump + Gasket and Pipe
Hey guys,
I have an LT4 HPFP with the pipe and gasket needed to swap it out. I have decided not to do Flex Fuel on my car; at least not yet. None of these have ever been installed.
Pump: 12642287
Pipe: 12642288
Gasket: 12623308
I will get better pics of everything this evening.
I am in Dallas, TX if any locals want to meet up. Asking $800 shipped obo for all 3 pcs
Pump: 12642287
Pipe: 12642288
Gasket: 12623308
I ordered 2016 LT4 injectors, part #12672374
Its my understanding the only other option was the modified LT1 injectors. Aside from costing more i didn't want to take a chance on them. I know GM spent a lot of time on spray pattern of these injectors and the katech injectors flow the same as lt4 (or maybe even a little less) but "make more power"? True or not i didnt want to take a chance.
I dont know why they have different versions, but based on what ive read on this forum the high flow version is the one to use. I think the modified lt1 injectors katech sells are modified by deatchwerks; where did you see those 165# injectors?
the 165# is the deatchwerks injectors saw them on instagram on chuckstuning page
555ctsv (09-04-2016)
I'm not sure on any differences between 2014-2015-2016 models. I have a 2016 and used the vin from a 2016 Z06 to get the fuel injectors. The PN i used for the injectors is different than that others had previously been using (not sure what year their cars were) but these seem to be working fine. The LT4 HPFP seems to have the same part # regardless of year.
Well i stand corrected... I guess there are fuel rails! (but no they dont need to be changed)
I used this thread a lot: https://www.corvetteforum.com/forums...e-for-lt1.html
i though that the lt4 rails flows better than the lt1. check post #4
https://www.corvetteforum.com/forums...t1-vs-lt4.html
The LT4’s direct injection system is similar to the LT1’s, but it features a new, higher-pressure engine-driven pump capable of delivering fuel at an astounding 2,900 psi. The LT1 pump is capable of “only” 2,175 psi. The LT4 also features a unique, higher-capacity fuel-rail assembly designed to accommodate the supercharger manifold. It’s fitted with injectors rated at 1.5 liters per minute, while the LT1 uses 1.2-lpm squirters.
