C4 Parts for Sale/Wanted C4 Corvette Performance Parts, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements, OEM, Aftermarket
Lunati SBC/L98/LTx valvespring kit
Old 09-20-2016, 10:04 PM
wikdwizard
wikdwizard's Avatar
Default Lunati SBC/L98/LTx valvespring kit
Asking $165 shipped. Only 12K miles.
Spring specs: http://www.lunatipower.com/Product.aspx?id=6706
Kit specs: http://www.lunatipower.com/Product.aspx?id=8668
Includes springs, locators, retainers, locks, and retainers/locks for 0.050" more spring height as well.
Last edited by wikdwizard; 02-16-2019 at 09:01 PM. Reason: Tired of too many parts lying around
Old 01-05-2017, 01:38 AM
wikdwizard
wikdwizard's Avatar
Still available.
Old 01-18-2017, 08:19 AM
tcollins
tcollins's Avatar
Will this work on a lt1
Old 01-19-2017, 01:14 AM
wikdwizard
wikdwizard's Avatar
Yes, they install in stock heads with stock valves with no modification.
Old 01-19-2017, 01:27 PM
tcollins
tcollins's Avatar
How much of a gain??
Old 01-20-2017, 01:44 AM
wikdwizard
wikdwizard's Avatar
Normally, installing parts such as these is necessitated by a cam change. IF one were to replace the stock items with what I am advertising here you MAY see a 10-15hp increase depending upon the condition of the springs you removed.
Old 01-14-2018, 07:50 PM
wikdwizard
wikdwizard's Avatar
Still available.
Old 03-05-2018, 01:51 AM
wikdwizard
wikdwizard's Avatar
Yep, still waiting for a good home.
Old 03-05-2018, 08:47 AM
RandomTask
RandomTask's Avatar
Going to make a correction here; you will not see any gain w/ these springs. You'd probably in fact, see a power loss if you simply changed the stock springs/keepers with these.
The spring kit allows for more aggressive cams. The way it does this is first, a narrower spring cross section (allowing more lift w/o binding the spring) and with a stiffer spring rate that makes sure the valve closes at higher RPM (no valve float). The engine has to overcome this stiffer spring rate and thus, takes power. Stock spring rate k=290lb/in. These springs are k=379 lb/in.
So while running a more aggressive cam does give more power, these pieces alone are to support an aftermarket cam.
Best of luck with sale.
Old 03-05-2018, 08:52 AM
wikdwizard
wikdwizard's Avatar
Power can be gained via better valve control relative to weak factory springs. That's why I threw the "MAY" conditional statement in there.
Old 04-20-2018, 12:58 AM
wikdwizard
wikdwizard's Avatar
Reasonable offers considered.
Old 05-01-2018, 11:49 PM
wikdwizard
wikdwizard's Avatar
Price lowered to $195 shipped.
Old 07-10-2018, 10:40 PM
wikdwizard
wikdwizard's Avatar
Still available.
Old 10-13-2018, 04:44 PM
wikdwizard
wikdwizard's Avatar
Ran across this box again today.
Old 02-16-2019, 09:02 PM
wikdwizard
wikdwizard's Avatar
Price decrease to $165 shipped.
Old 07-27-2019, 02:21 PM
wikdwizard
wikdwizard's Avatar
Old 07-27-2019, 10:45 PM
BLKMAMBA
BLKMAMBA's Avatar
Old 07-27-2019, 10:49 PM
BLKMAMBA
BLKMAMBA's Avatar
I have these on my 93 LT1. the K5 kit is what you need for LT1's for seals to fit.
To Lunati SBC/L98/LTx valvespring kit
Quick Reply: Lunati SBC/L98/LTx valvespring kit
