Sponsored by: GEM Motorsports
Sounds like rumble strips
Old 09-26-2016, 02:51 AM
dckotwicki
dckotwicki's Avatar
Default Sounds like rumble strips
I own a 2016 Z06 with 3500 miles on it. Recently went into northern Michigan for a weekend get away. The roads are smoother and quieter with less traffic noise. Some roads have rumble strips imbedded into the side and center of the road to get your attention when you wander left or right. These get your attention big time. During the drive, I began to notice a similar but quieter noise. I began to study the road surface but could find nothing to connect to this noise. I started to look elsewhere for the source and discovered a direct connection to the AFM (active fuel management).
With the cruise control on and on a relatively flat road I began to notice this subtle rumble noise (similar to hitting rumble strips but much quieter) occurring when the engine was in 4 cylinder mode. When it went back to 8 cylinder mode, the noise went away. The noise always happened before returning to 8 cylinder mode. The duration of the noise ranged from 1-2 seconds to several seconds (5-10 seconds) and always disappears once the engine is back to 8 cylinders.
I am not a mechanic and do not know the mechanism that causes the engine AFM to activate, but I wonder if there is something acting up in the system that activates the AFM.
Anyone experience anything like this or have any possible explanation for what is happening?
The engine had the 500 mile oil change at the dealer and again at 1000 miles. Both with Mobil One. Oil level is where it should be and shows 65% oil life.
The following 3 users liked this post by dckotwicki:
C7/Z06 Man (09-27-2016), Russell ONeal (06-23-2017), sTz (09-26-2016)
Old 09-26-2016, 12:49 PM
sTz
sTz's Avatar
Received 2,424 Likes on 1,597 Posts
Edit: I heard something similar, but found that it was actually the road...
Old 09-26-2016, 02:49 PM
BOBSZ06
BOBSZ06's Avatar
Yes! I have an A8 and experience the same noise when seeing the engine move from 8>4.
I believe it to be the belt tensioner vibrating when the 8>4 switch is made for which there is a TSB.
I am waiting to see if it starts leaking oil before taking it in for replacement.
Here is a link to the PIP 5185A...rattle or flutter, which describes it just fine.
http://www.stingrayforums.com/forum/...-pip5185a.html
Old 09-26-2016, 03:18 PM
subfloor@centurytrans
Supporting Vendor
subfloor@centurytrans's Avatar
2020 Corvette of the Year Finalist (track prepared)
C6 of Year Winner (track prepared) 2019
I also experienced this for the first time last Friday and when I first heard it I looked around me on the freeway expecting to see a diesel truck that was accelerating.
Old 09-26-2016, 03:25 PM
Supporting Vendor
I don't think the TSB accurately describes the problem, because the noise occurs right up until the car goes from V4 mode to V8, not when the transition occurs.
Old 09-26-2016, 03:28 PM
RichieRichZ06
Supporting Vendor
Support Corvetteforum!
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
I think the "rattle" from the belt tensioner is a separate noise and usually only effected earlier Stingrays. I have not witnessed that issue on 2015 or 2016 models yet.
I'm also curious as to what this noise is. Subfloor and another C7Z customer have been experiencing this and I can't find any TSB or other info from GM.
dckotwicki (10-24-2016)
Old 09-26-2016, 03:44 PM
BOBSZ06
BOBSZ06's Avatar
Mine only occurs when I see the V8 > V4 transition occur and lasts a few seconds. If I hit the throttle a little to go from V4 > V8, it stops immediately.
All occurrences during the transition stages. Yes, it can last longer but not always while in V4.
Old 09-26-2016, 04:48 PM
BOBSZ06
BOBSZ06's Avatar
For those that wish to replace the belt tensioner:
Parts:
http://www.trunkmonkeyparts.com/auto...d-pulleys-scat
Install video:
https://www.corvetteforum.com/forums...uteginger.html
Old 09-26-2016, 06:53 PM
sTz
sTz's Avatar
I only experienced this anomaly once, but will keep an eye on it. Thanks for the information
Old 09-26-2016, 07:41 PM
sTz
sTz's Avatar
I just read the thread and viewed the vids posted by Bounty Hunter 6 (provided by BOBSZ06 above). He described the noise as a "whining sound, very much like what a car with a bad power steering pump would make, but increasing with throttle whether under load or not."
While the tensioner may still be the culprit, this is nothing like what I heard or experienced, or what the OP described. We might be talking about two different things...
I have an M7. I was in Touring mode and not in Ecco mode, so my car shouldn't have been sequencing from 8-4 and vice versa, right?
Old 09-26-2016, 07:44 PM
BOBSZ857
BOBSZ857's Avatar
I have noticed this as well on long drives while cruising alone very smooth roads. I have an A8 and the noise seems to be coming from under the dash on the drivers side or the front drivers side in engine bay.
Old 09-27-2016, 09:10 AM
BOBSZ06
BOBSZ06's Avatar
Correct, the noise in that video is not what this discussion is about.
The videos are for the replacement of the belt tensioner only.
Old 09-27-2016, 11:53 AM
dckotwicki
dckotwicki's Avatar
Wow! Subscribing...
I experienced the exact same anomaly yesterday for the first time while descending down a long grade in 6th gear. It only lasted for about 5-6 seconds, but it sounded as you had described, a subtle rumble strip-like noise, which I could actually feel in the pedal and shifter.
I never suspected that it could be the AFM, as the Z06 doesn't have the rear AFM valves, so the sound/vibration must be coming from the engine bay, but it felt like it was coming from below the chassis.
I dismissed it as I was unable to later duplicate the condition, but came across your thread and now I'm curious?
While certainly plausible, how did you conclude that it was due to the AFM? Have others reported the same... Thanks
Edit: I have a M7 and Corsa cat-back exhaust. Do you have any exhaust mods? A8 or M7?
I have no mods at all.
Note: My noise always happens while in V4 mode and always before returning back to V8 mode.
Also: People seem to be connecting AFM (Active Fuel Management) to the performance exhaust. AFM is the system that toggles the engine between V4 and V8 mode for improved fuel economy.
What I am observing seems to be related to the Active Fuel Management system and not the exhaust system.
Old 09-27-2016, 02:39 PM
C7/Z06 Man
C7/Z06 Man's Avatar
The light rumble strip sound happen to me today, coming home from having the airbag reprogram done. I had not really noticed it before. I have the A8. For me cruising around 69 mph the sound would happen on level road at very little throttle, if I increased the throttle by the smallest amount or let off the gas the sound stopped.
I was concerned because the dealer was "just in" the ecm for the airbag recall but after reading this I think the OP is right on the money! I will be checking this out again when I go for a drive later.
dckotwicki (11-08-2016)
Old 09-27-2016, 06:55 PM
sTz
sTz's Avatar
Unable to duplicate... Maybe it was the road
Edit: Confirmed, it was the road.
OP, good luck finding a resolution
Old 09-27-2016, 08:53 PM
7.0ltrpower
7.0ltrpower's Avatar
... could it be the small torque tube vibration in Eco-mode... Tadge discussed long ago... Saw in video..
Old 09-27-2016, 09:37 PM
gve
gve's Avatar
Mine did that also it's not good having your engine only run on 4 cylinders, that's why it vibrates under light load before going to V8. I bought the Range AFM eliminator which keeps it in V8 all the time. A 650 HP engine will not run smooth when exposed to light acceleration under load and only firing on 4 cylinders. The AFM is the worse thing for this 650 HP engine, plus they tend to use oil after you get more miles on the engine. I was told by the Corvette museum when I picked up my car to keep the A8 in Manual for the first 500 miles during the break in so it fires on all 8. Google Chevrolet AFM oil consumption and you will find more info.
BOBSZ06 (11-08-2016)
To Sounds like rumble strips
Old 09-27-2016, 09:58 PM
C7/Z06 Man
C7/Z06 Man's Avatar
Default Afm or dod
Well I went for another drive including down the same road.
There is little doubt in my mind it is the AFM in my case.
As mention here there are products on the market that remove AFM.
Old 09-28-2016, 10:10 AM
wagoetzmann
wagoetzmann's Avatar
I drive my A8 to work on a very smooth, hilly, 2 lane with very little traffic. With cruise control set at 62 mph every downhill coast the engine will go into V4 mode then at the bottom of the hill back to V8 mode. When going from V4 back to V8 the engine makes a farting noise, the car shutters and I see the vacuum gauge jump. I believe it to be the AFM valve lifters pumping back up. It is very annoying to say the least.
Old 09-30-2016, 03:39 PM
Supporting Vendor
Default I managed to capture the issue on video
You have to listen fairly carefully with the sound turned up, but in all three videos the growling sound it makes right before switching back to V8 mode is definitely noticeable. Please let me know if this is the same thing that other people have been experiencing.
The following 2 users liked this post by subfloor@centurytrans:
BOBSZ06 (11-08-2016), okaythen (06-26-2017)
Quick Reply: Sounds like rumble strips
