New member in SoCal
New member in SoCal
Hello All,
I'm new to this CF forum. I bought a Blade Silver 09 Base model with Auto Transmission in August. I'm very happy with the car.
I have couple Questions and Needs Members helps me.
Is it normal that the previous Owner installed the Wheels and. Tires 245/40/18 front and 285/40/18 rear on Gumby's wheels style. Don't know if it's OEM.
A full Z06 exhaust, from Exhaust manifolds to Tail pipes.. Do I needed a tune or I 'll have issues in the Future with Smog check here in California.
The Dealership already sent me the 2017 sticker.
Thanks All,
Dan
BrknWndC6 (09-26-2016)
Congratulations on your purchase. 18 inch wheels feont and back? Tires are all 40-18? I thought you would have an issue with traction control stuff. I would tune due to changing rhe exhaust. Ca bubbas will soon chime in
Received 1,675 Likes
Congrats on your new car! No that's not a factory set up.
If it's from the dealership, I'd imagine it has the extra cats that the cars got recalled on here. So you should have 2 in the headers and then 2 more in the mid pipe. Assuming that's all there, you should be fine with smog.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Enjoy your new ride, enjoy the Fall!
Cool & Welcome! I'm guessing that your Gumby's are aftermarket knockoffs since OEM wheels should be:
Front: 18 inch x 8.5 inch - Rear: 19 inch x 10 inch.
Tires front: P245/40ZR18 - Rear: P285/35ZR19
Good luck with the inspection if he looks very carefully. The Smog check here is now a more thorough inspection & an OBDII plug to check for codes. There is no sniffer anymore for newer cars.
