RPI Designs C7 Corvette Stingray/Z06/Grand Sport NPP Mild2Wild Exhaust Controller!!!
Platinum Supporting Vendor
2014 2015 2016 2017 C7 Corvette Stingray Z06 and Grand Sport Mild2Wild Exhaust Controller for NPP
Finally available! The C7 Corvette Stingray/Z06 and Grand Sport NPP Mild2Wild exhaust controller. Many C6 owners will remember the awesome features of the Mild2Wild...we finally have the Mild2Wild NPP exhaust controller available for the C7 Corvette.
This revolutionary product lets you control your, C7 Corvette bi mode exhaust system on demand via a tiny wireless remote or the Homelink feature in your car . One of the coolest technologies is the “bi-mode” exhaust. Whisper quite up until 3500 RPM and then a wide open race car sound as the flaps located in the tips open.
Please note for this product to work your car MUST be factory equipped with a Bi mode exhaust system. If you have any question please call us at 888-257-8515
Item # C7M2W ON SALE FOR $89.95 Use coupon code RPICHRIS5 and save an additional 5%
Website Link : http://www.rpidesigns.com/shop/item....6-grand-sport/
__________________
The following 2 users liked this post by RPIDON:
marcouvo (10-31-2016),
ssidekickbp (10-21-2016)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Is Bi-Mode Exhaust system equal to the NPP system?
Elmer
Elmer
HI Elmer, They are two different names for the same thing. If you car is equipped with it the exhaust tone can change whether the car or you determine it. It has been around for a long time, The earliest I have known about it was in 1970 there was an option for it on the Pontiac GTO. What we are offering here is a different way other than the factory way for you to control the exhaust sound on your C7 Corvette. By a push of a button you can have the exhaust system loud all the time and with a push of the button it will go back to stock operation.
Order placed.
Thanks,
Elmer
Thanks,
Elmer
Actually, I believe this does not work the same as the original Mild2Wild.
The original Mild2Wild, if I recall correctly, allowed one to force the valves open or closed at all times.
This device appears to not be able to force the valves closed at all times. It will choose between valves open all the time or valves controlled by computer (which is not valves closed all the time).
Details here from a year ago, not sure why it was never made a sticky:
https://www.corvetteforum.com/forums...ob-how-to.html
Woodson (10-31-2016)
There is no way the C7 settings will allow NPP valves to open at idle and lower RPM settings. The fuse remote circuit will allow it.
Website Link : http://www.rpidesigns.com/shop/item....6-grand-sport/[/B]
Thanx for posting. Where does it plug into? Instructions included?
I'm Batman..
Pro Mechanic
So this will not work for those looking to retrofit NPP exhaust on their non NPP C7 to control the valves.. bummer.
Also ordered, and you're right the Discount Code RPIDON5 does not work.
Ordered one yesterday! I will report back on how it works...
-M
-M
Here is a set of the instructions we will also be making a video shortly of the installation process. This is one of the easier things to install on a C7 Corvette. If you have any questions you can reach me at 888-257-8515 ext 2. Thanks, Don
