1965 High Beam Issue
Navigator
Hi folks: I'm Tom from Tennessee -- just brand new to this forum. I've been a C2 owner for nearly 40 years and thought I'd been through most ... but my lighting problem stumps me. I've tested all four headlights and they're all good. I put in a new dimmer switch. I've put in a new light switch. Still, when I pull on the light switch, all I have are low beams. I'm wondering if it's something in the wiring harness or a connection at the firewall ... or just old like I am and doesn't work. It's a frustrating thing. I need some headlight help. Thanks so much.
Received 1,679 Likes
Welcome to the CF! You should post that question in the C1 & C2 section of the forum for a quicker response.
Navigator
Thank you. Forty-plus year experience in C2 ... first-day newbie to the forum. I'll learn to negotiate the turns and curves of the forum eventually. Thanks for the tip.
Pro Mechanic
Received 3,952 Likes
Welcome to the forum!
Good luck with your C2 light issue!
Navigator
Navigator
