Dual Cubby Gauge Pod by MMS
Supporting Vendor
Like my single pod you have seen for a while; This allows access to the USB port and does not require fasteners to hold in place.
Made in the USA and in stock
Purchase link:
http://www.mightymousesolutions.com/...0-c55972c73ada
__________________
Solutions for the common gearhead #made in USA
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
Earl H (04-26-2017)
Received 1,762 Likes
ttt
David that looks great man. Will mark this one looking at doing a small blower before warm weather.
Supporting Vendor
adding a version of the dual pod with one hole at 60mm next week (Needed for my own build, so perhaps someone else needs it too!).
Supporting Vendor
Does the single hole version have the same overall dimensions as the dual?
Supporting Vendor
no it is smaller to retain more storage
there is a pic on the site link
Supporting Vendor
that part i cannot help with from here sorry! either corner will lead to behind the dash, but go careful as there are some ducting you would rather not drill into, feel behind with your hands to confirm available space first.
you can eventually pull the entire box out but is a lot of work.
here is some of it
here is some of it
Supporting Vendor
ttt
Buddy great DIY on this it is all the same also guys as the 3lt also on pulling it apart. Great job man... Robert
Do you need to pull the entire dash apart like in the video? Is it possible to just drill a hole in a corner of the cubbie and snake the wires into the engine bay through the fire wall?
Just wanted to thank everyone from this tread i was PMing for advice routing the wires for my AFR gauge to my cubbie. I ended up penetrating the firewall via the path of the hood release cables. I used a hanger to snake the wires behind the dash into the cubbie and i grabbed power from the cigarette lighter. Mounted it in the Mighty Mouse single pod.
Supporting Vendor
most of these shipping are now brushed stainless steel vs the plain aluminum at no additional cost
here is some of it
https://www.youtube.com/watch?v=SlG75ze2Udc
here is some of it
I just installed an Aeroforce intercepter 2 1/16" gauge in just 1 hr.
Just pop out the USB Port in the cubby and you will have enough room to fish a light weight coat hanger down through the drivers side dash and pull your wires back through.
Then just drill a 1/2" hole directly behind the gauge,
Put a 3/8" stop on the drill bit so you do not get into any ducting behind the cubby.
Then fish the wire from the USB to the hole you just drilled.
This whole process took 1 hr from start to finish.
The hardest part was working under the drivers side dash as it is a small area.
I would kill if someone made a boost gauge to go where the lighter is popup and all!
Supporting Vendor
