Sponsored by: GEM Motorsports
Katech Ported Throttle Body - Install
Old 01-14-2017, 01:26 PM
mike123460
mike123460's Avatar
Default Katech Ported Throttle Body - Install
About to do the install today, is it just a simple plug and play? Need to disconnect battery or anything? No CEL?
Thanks,
Mike
Old 01-14-2017, 01:51 PM
Doug Z06
Doug Z06's Avatar
Installed mine a couple weeks ago. Maybe 10 minutes total time to install. No battery disconnect no CEL. And a nice noticeable difference in power delivery.
Old 01-14-2017, 02:42 PM
Checkmate1
Checkmate1's Avatar
Thanks,
Mike
Can you take pictures or video of the install? It would benefit the forum!
Old 01-14-2017, 03:32 PM
WuTang
WuTang's Avatar
I second that!
Old 01-14-2017, 08:27 PM
mike123460
mike123460's Avatar
Sorry guys, didn't see the comments before I did it. Literally the easiest install. Use a flathead screwdriver to take off the silver band holding the throttle body. And then a ratchet to remove the 4 screws. I'll try to post a picture tomorrow if I remember.
Old 01-14-2017, 10:28 PM
Hawkbarr
Hawkbarr's Avatar
Also please share cost, supplier, and performance gain you experience. I've been looking at this mod for awhile and must have missed previous posts (if any) on the topic.
Thanks
Hawkbarr
Old 01-14-2017, 11:24 PM
Bigeasyvette
Bigeasyvette's Avatar
Going to do the same mod next week when my aFe CAI comes in, doing both the throttle body & CAI change at the same time. I am using a Weapon X ported throttle body.
Old 01-14-2017, 11:34 PM
Hawkbarr
Hawkbarr's Avatar
BigEasy,
How much is the Weapon X TB? I have the AFE CAI, AR headers and exhaust already and want to do a pulley swap and TB at the same time so we just have to retune it just once.
Thanks
Hawkbarr
Old 01-14-2017, 11:42 PM
Bigeasyvette
Originally Posted by Hawkbarr
BigEasy,
Thanks
Hawkbarr
$ 350.00, with a $ 150.00 core credit when you send back the original.
seems to have good reviews on the weapon X unit.
Old 01-14-2017, 11:54 PM
Hawkbarr
Hawkbarr's Avatar
Thanks BigEasy, I will check it out.
Old 01-15-2017, 10:30 AM
Wulverine
Wulverine's Avatar
St. Jude Donor '15
Just to add. Rachet and 10mm socket with extension work fine for the 2 top and lower right bolt, but I had to use a 10mm wrench for the lower left bolt due to clearance issues with the intake tube
Old 01-15-2017, 08:20 PM
Bigeasyvette
??? How does replacing the CAI & throttle body affect the GM warranty ?
Old 01-15-2017, 11:58 PM
foreverfuelie
foreverfuelie's Avatar
Old 01-16-2017, 07:08 AM
Wulverine
Wulverine's Avatar
St. Jude Donor '15
I think most would agree that a CAI and stock ported TB are considered power-train warranty friendly mods, but ultimately that is up to GM.
Old 01-16-2017, 08:15 AM
8850's Avatar
As Doug Z06 says, it's a 10 minutes job. I would replace it with my stock tb before going to the dealer. Not sure about the intake but probably replace it too with the factory.
I would think as long as no tune has been installed we should be good on warranty.
Old 01-16-2017, 08:51 AM
mike123460
mike123460's Avatar
Thanks
Hawkbarr
Katech Ported Throttle body was 250$ after shipping. I can definitely feel a slightly increased throttle response. It doesn't get 100% get rid of the lag, but it's the best you're going to get without a tune and voiding your warranty. I would recommend it. Cheap mod.
Z0HS1CK (07-29-2017)
Old 01-16-2017, 10:20 AM
SterlingDrive
SterlingDrive's Avatar
Question; are those with the M7 also doing this mod?
Dave
To Katech Ported Throttle Body - Install
Old 01-16-2017, 10:22 AM
Wulverine
Wulverine's Avatar
St. Jude Donor '15
Dave
Seems those with the M7 are the ones that complain the most about throttle hesitation.
The following 3 users liked this post by Wulverine:
Bigeasyvette (01-16-2017), SterlingDrive (01-16-2017), Z0HS1CK (07-29-2017)
Old 01-16-2017, 01:45 PM
Doug Z06
Doug Z06's Avatar
For those interested in seeing the difference between a stock (first photo) and a Katech ported throttle, see below. I highly doubt a ported throttle body would have any affect on warranty. Since it's a 10 minute job you can always swap it out before going to the dealer if you have a concern.
Old 01-16-2017, 01:54 PM
Bob U
Bob U's Avatar
Looks great, can you show us pictures from the back side.
Quick Reply: Katech Ported Throttle Body - Install
