Poor A-pillar trim fit.....
Dr. Detroit
Received 3,892 Likes
I have purchased some A-pillar trim from Corvette Central and the fit is awful....it does not hug well around the windshield frame and leaves much exposed looking at it.....
Anyone else experiencing this?
Car is a 72'.....
Jebby
Car is a 72'.....
Jebby
Yes same problem with my '73 passenger side. I believe I purchased mine from Wilcox and I don't believe it matters where you purchase them ,
I think they are all the same, and what I call the 1st generation Velcro snaps don't even come close to snapping together.
Many reproduction parts seem to need a little work.
I had to heat mine up and shape them better to the pillars.
Be careful with a heat gun as they will easily get too hot.
The piece that goes between the tops needed to Be reshaped at the rear to fit the original halo panels properly.
Seems that's just normal practice, some are much better than others.
Dr. Detroit
Thanks for the replies....I will break out the heat gun....
Jebby
Jebby
The factory A-pillars are NOT straight; there is a slight bow in them. That's why the after-market pillars will not fit well. Also, the snap connectors (like super-big Velcro pads) are not the same in configuration.
I ended up drilling out the rivets in the repop snap-pads and swapping over the ones from the factory. I also did a little 'massaging' of the pillars to get them to fit. Finally, I had to re-dye them cause the color was off.
I called the vendor about this and discussed all the things that were wrong with them and offered to send them my originals so they could "improve" their product. Bottom line: they couldn't care less.
I no longer buy anything from them.
Dr. Detroit
So are there any A-pillar trim out there that fits?
Jebby
Jebby
Both Corvette America and EC Products make pillar post moldings. I'm not sure if Al Knoch makes his own, or buys them from Corvette America.
Personally I like the CA ones more than EC's, but CA's do seem to have a little more padding, which makes them more difficult to install.
I've found that a little weatherstrip adhesive on each "Velcro" pad, helps keep the moldings in place.
When spending top-dollar prices on such parts, it doesn't make any sense to be forced into making 'band-aid' repairs...
croaker (02-28-2017)
I just got a pair from Corvette Central for my 73. Like others the fit is not the best but the biggest thing for me is where the vinyl cover wraps around the edge near the window seal it has been cut off rather than wrapping around like the original. This leaves a small area of the foam backing that you can see when it is installed. I can minimize this by dying that edge that is cut and coloring the foam so it won't stand out.
I am also seriously considering attaching mine with screws as the 78 would be. I might try bending the things a bit first so those plastic fasteners will engage. Since my car is a driver I'm not so concerned with correctness as functionality. I don't know, but it sure is disappointing.
Anybody know how long the attaching screws would be for a 78?
Dr. Detroit
The heat gun trick will not work as the backing is metal......
I am going to tweak them but quit playing with it for now.......fortunately my windshield frame is perfect and blacked out........leaving them off for now.
Jebby
Jebby
It's been 10 or 12 years since I redid my interior. I used a mix of different parts from different vendors. I used Corvette America for the A pillars and had them stored for a long while before I discovered the same thing you guys are finding. They flat out suck compared to the stock. I never did get mine to fit like I would like them to. I have basically lost interest in them now. I notice them every time I get in the car. They are so hard to remove just so you can tweak on them. It's been a while since i have messed with them but don't you have to remove the upper dash pad? Probably the main reason I have not reworked them.
Foam glue tape is your friend when trying to get these POORLY designed parts to work....just saying. It is almost INEXCUSEABLE that these parts are so BADLY made!
I am having the same problem with my 81. One of the rivets was broken off. I think I am just going to drill new holes and make everything fit that way. The metal piece that the rubber strip attaches to is all loose and moves around.
