'03 Base Coupe mirror PN?
Oldtimer
Anyone happen to know the part number for the passenger side mirror on a 2003 base coupe? With memory and heat. Te whole assembly including the housing. I must be "internet search challenged" today.
Memory and heat doesn't matter, it's the Auto-Dim feature that makes the difference in the part numbers AND the price.
RPO DL8 = 10416056 Standard mirror assembly
IF you were to have the electrochromic (Auto-Dim) feature the RPO code would be DD0 and the part number is 10416058.
These are paint to match of course.
HTH
HTH
Received 19,306 Likes
'20-'21-'22-'23-'24
The auto dim feature is not applicable to the passenger side mirror. It is only on the driver's side outside mirror. And thanks for the part numbers - don't need to replace mine now, but I do keep the part numbers on file just in case.
LoneStarFRC (01-17-2017)
Oldtimer
Thanks! DL8 it is.
HTH
HTH
When looking up part numbers for a 2000 for example, the DD0 variant is not shown at all, vs a 2003 in which the DD0 (auto-dim option) IS listed and specifying different part numbers for both the d/s AND p/s versus the part numbers for non-DD0 cars.
'20-'21-'22-'23-'24
I know my '03, which has the auto dim feature, does not have it on the pass side and the owner's manual only lists it as being on the driver's side. Who knows what GM was thinking.
Received 1,679 Likes
