Corvette Central / New C5 Door Panels
Talk about a CORVETTE TAX
http://www.parts123.com/corvettecent...50c&ukey=52977
For that price I'll keep my slightly delaminated vinyl one's Thank You !
Mine are coming off at the arm rest. Not bad and hardly noticeable unless you really look at it. I haven't worried to much about it yet.
66dts-v (01-16-2017)
There is a DYI fix for that
https://www.corvetteforum.com/forums...up-how-to.html
Received 19,305 Likes
'20-'21-'22-'23-'24
Lou - you might also check with one of the used parts vendors for the door panels. They may have one in excellent condition for a better price. Or try that fix mentioned by Smoken1.
Seems like about double the price of what they would be worth (to me) - especially since apparently they employ the same failed vinyl process as far as I can tell. Wish they would release a set with upgraded material/process similar to the C6 upper panels which don't rely on "glue" to maintain those deep compound curves.
1/4 mile/AutoX
see them on e-bay all the time for around 100.00 don't know how good they are ??? First place I would check if I needed them would be Vettenuts !!!
I was just going to pull it and re-glue it like it was originally, only using a better glue. I need to re-glue my headliner as well. Drilling holes just to get to the area seems a little extreme to me. And it doesn't look as smooth as I would like once finished.
3M glue, a little heat to make the vinyl pliable and presto.
Smoken1 (01-16-2017)
Received 3,812 Likes
I bet C Central will sell a ton of those..
With lots of C5 owners looking to buy regular fuel because premium to too expensive, I bet they wont be able to keep those panels in stock, and to think if you could afford to buy ten set of them, you could buy a C5.
Bill aka ET
Bill aka ET
SG Lou (01-22-2017)
