balancer
Old Jan 12, 2017 | 10:11 PM
namvet6869's Avatar
namvet6869
Default balancer
Just got my 2000. Has 84500 miles. Don't know anything about history of the car. No major codes. Been reading all the things that can go wrong with the early C5. Believe column lock fix has been taken care of. Has new batt but not gel type. Putting mat under it and checking it often. Nasty weather her so I only put couple hundred miles on it. Runs great. Been reading that the balancer will most likely go out. Are there any early C5's that the balancer has NOT gone out!!!!!!!! Just trying to learn what I really need to keep an eye on. Thanks
Old Jan 12, 2017 | 11:12 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Is it wobbling ??? I have a 99 that I drive the crap out of with 70,000, balancer smooth as glass !!!
Old Jan 12, 2017 | 11:32 PM
Slo Yelo C5's Avatar
Slo Yelo C5
Welcome! You made a wise decision...Millennium Yellow C5s, specifically from 2000, are the best Corvettes. I should know with a Millenium Yellow 2000 myself.
To answer your question...it seems doubtful. I've heard the failure rate is literally every LS1. Mine has 21,000 miles and the balancer already wobbles. Luckily if you get an ARP bolt ($35) and ATI balancer ($400 or so) and pay $600-$800 for labor, it's a one time only fix for life. I'm doing mine as soon as there is nice spring weather.
Old Jan 13, 2017 | 12:09 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Ut OH... I have to jump inhere.
there are two separate balancer issues
1) the bolt backing out
2) elastomer bond failure
a) there are three components to a factory Balancer
Outer pulley
Inner balancer
Elastomer bonding agent and vibration damper
Over time 40 % of balancer failure is from the elastomer breaking off in chunks, do to excessive heat. This will cause total separation of the inner from the outer. Both problems are well documented.
With replacement, no matter which balancer you choose, you need a new bolt, and also , very important but often over looked, a new Crank seal.
Bill aka ET
Old Jan 13, 2017 | 06:50 AM
silverbird's Avatar
silverbird
St. Jude Donor '08
"To answer your question...it seems doubtful. I've heard the failure rate is literally every LS1. Mine has 21,000 miles and the balancer already wobbles. Luckily if you get an ARP bolt ($35) and ATI balancer ($400 or so) and pay $600-$800 for labor, it's a one time only fix for life. I'm doing mine as soon as there is nice spring weather."
I replaced my balancer last summer as preventative maintenance. I took some heat from the "if it aint broke, don't fix it" crowd. I went with the ATI balancer, ARP bolt, new crank seal, new belts and hoses.
My car is a low mileage (16,000) 2002 Z06. I've tried to address all the issues that C5's are known for, including the LS6 valve springs.
I plan on retiring next year and driving the hell out of the car. I've always been fond of people that take care of older cars and drive them. This was my goal when I bought my Z06 many years ago.
Old Jan 13, 2017 | 07:52 AM
Ron C!'s Avatar
Ron C!
My 2000 has 139K on it and it is just now developing a slight wobble and a bit of a squeaking noise. Have the parts, waiting for a time slot to get it done.
Old Jan 13, 2017 | 12:59 PM
Slo Yelo C5
Outer pulley
Inner balancer
Bill aka ET
Thread saved for future use for me. I'll let my shop know to replace the crank seal.
I just saw in another thread you live in SE PA! I used to live in Bucks County...now I live in Chester County, near the Delaware border. Where in SE PA do you live?
Old Jan 13, 2017 | 03:46 PM
tombrammer's Avatar
tombrammer
Does the steering rack have to be removed to replace this, it looks very tight in there? On my c4 it is tight but you can remove the balancer with the rack still in there, any good how too's on this I can read? Thanks
Old Jan 13, 2017 | 03:50 PM
Evil-Twin's Avatar
Evil-Twin
Rack has to be moved..
Old Jan 14, 2017 | 11:00 AM
Gordy M's Avatar
Gordy M
If you are going to replace with a stock balancer, you should also make sure they (or you) pin the crank. Especially if you are going to run it hard. There are several track in Michigan I run and all of them have a large portion of the track where the Manual trans is run at third. After about 1100 miles of HPDE time my front bolt decided to take a walk....I still have the padding on the underside of my hood to show what happens when you are at speed and all the belts fly off.
Old Jan 15, 2017 | 03:20 PM
El original's Avatar
El original
Is that what retired guys do? "Drive the hell out of their Corvettes" I plan on retiring this spring but driving the hell out of my Corvette never crossed my retirement plans!
Old Jan 15, 2017 | 04:19 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
Sorry you feel that way.
That's what this retired guy is planning to do. (god willing)
I never was a fan of sitting in parking lot car shows or cruise nights.
Not planning on racing my Corvette because I got that out of my system years ago with other cars I've owned.
I plan on taking my Corvette for a 2 month road trip around the country and visit some National Parks along the way. After that, road trips to various car races around the country (as a spectator/photographer).
Over the years my job has kept me too busy to attempt those types of things.
Silverbird
Old Jan 17, 2017 | 02:34 PM
Raith's Avatar
Raith
my 04 made it to 196k miles and never had a balancer issue. blew up a piston at 196k, but thats another story... arp bolt and a new seal and you should be fine.
Old Jan 17, 2017 | 05:35 PM
UM Rebel's Avatar
UM Rebel
Yep, that's what this retired guy does!
To balancer
