C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Oxygen Sensor bank 1 sensor 1
Old 01-16-2017, 05:14 PM
Fabio-Z06
Fabio-Z06's Avatar
Default Oxygen Sensor bank 1 sensor 1
I have codes that went on my car (P0030 and P0135) which is for the oxygen sensor on the drivers side before the cats. I just can't seem to find it though?
Can someone please direct me to exactly where the o2 sensor is on the drivers side? Anyone have a schematic or an actual picture or video of where it is and how difficult it is to get to and replace?
Old 01-16-2017, 06:26 PM
LeftLane Z06
LeftLane Z06's Avatar
pic of the cats.... located right off the exhaust manifold.
Old 01-16-2017, 06:36 PM
LeftLane Z06
Probably have to drop exhaust manifold to change the pre cat 02 sensor.
Old 01-16-2017, 06:58 PM
Fabio-Z06
Fabio-Z06's Avatar
God forbid it was the o2 sensor after the cats that could be changed out in two minutes....
Thank for the help guys.
By any chance anyone have a video of this being done?
Old 01-16-2017, 08:50 PM
Fabio-Z06
Fabio-Z06's Avatar
Forgot to mention that I do have dynatech headers and full corsa exhaust. Would the o2 sensors still be in the same area?
Old 01-16-2017, 09:01 PM
LeftLane Z06
should be easier to get too. Still might have to remove all the header bolts to allow for movement to get 02 sensor out. Not a hard job...maybe a hour or two.
Old 01-16-2017, 09:05 PM
LeftLane Z06
But I think you can get it out with no problems. You should be able to see and get to it once you get under the car.
Fabio-Z06 (01-16-2017)
Old 01-16-2017, 09:34 PM
Fabio-Z06
Fabio-Z06's Avatar
Really appreciate the info.
Old 01-17-2017, 08:30 AM
redbird555
redbird555's Avatar
Just for anyone who read this thread you can change out the top O2 sensor without dropping the manifold on a stock car. Usually under the car is easier
Apocolipse (06-07-2021)
Old 01-17-2017, 09:59 AM
Fabio-Z06
Fabio-Z06's Avatar
Hopefully that is the case and maybe a bit easier as mentioned above with the dynatech headers. I guess once I have a minute to get under the car I'll figure it out.
Old 01-28-2017, 09:30 PM
Fabio-Z06
Fabio-Z06's Avatar
Their are only 2 oxygen sensors per side right?
I just went under the car and literally removed the first (bank one) o2 sensor in about 3 minutes. By reading a few of the post above it seems as though this should have taken me at minimum, an hour. Did I remove the wrong one? The other sensor closer to the back of the car seems like it would be more difficult to remove.
Here is a pic if both spots.
Old 01-28-2017, 09:34 PM
Fabio-Z06
Fabio-Z06's Avatar
One more
Old 01-29-2017, 02:23 AM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
The one you removed is a pre-cat O2 sensor, the other pic with the two next to each other, those are post-cat sensors.
The location and relative difficulty of removal is going to vary based on the brand of header. For example, it would take me a lot more than five minutes to replace the front O2 sensors on my Kooks.
Pre-cat sensors provide the ECM with a feedback loop for fuel mixture adjustments. The post-cat sensors are just there to check the cat efficiency and operation.
Old 01-29-2017, 11:17 AM
Fabio-Z06
Fabio-Z06's Avatar
Yes. I removed the "upstream" as I've just learned it to be called while
trying to order it from auto zone.
Hardest part was getting a jack under the car. While down there should I replace others? Probably not worth it I'm guessing right? I guess just change if another one goes at some point.
Old 01-29-2017, 01:12 PM
Dan_the_C5_Man
Well, unless they were poisoned by coolant or other foreign material, O2 sensors are very durable and last for tens of thousands of miles..
How many miles on these? If very high mileage, then yes, replace the other pre-cat O2 sensor.
Remember, the pre-cat sensors are critical to engine fueling. The post-cat sensors are more like a yes / no feedback loop to make sure you haven't removed the cats or to validate they are working properly. Most tuners eliminate the post-cat O2s from the ECM configuration.
Fabio-Z06 (01-30-2017)
Old 01-29-2017, 02:07 PM
Fabio-Z06
Fabio-Z06's Avatar
My car only has 9000 miles. I guess I'll leave the others alone. One of the wires seemed to have been a bit melted from being to close to the exhaust.
Old 02-01-2017, 07:17 PM
Fabio-Z06
Fabio-Z06's Avatar
I received my o2 sensor and replaced it. Do I need to have a code reader eliminate the check engine light or do I just drive it a few times and it should shut off?
Not sure when I'll want to drive it if I need to go that route since they salted the roads. I don't want to take it out on salted roads.
To Oxygen Sensor bank 1 sensor 1
Old 02-01-2017, 09:28 PM
Dan_the_C5_Man
You can either reset it with a reader or drive it a few cycles until it clears on its own. Also, check the related fuse.
Old 02-01-2017, 09:41 PM
Fabio-Z06
Fabio-Z06's Avatar
Thank you.
Would you happen to know how to check which fuse is related to the specific o2 sensor?
Old 02-01-2017, 10:44 PM
Dan_the_C5_Man
Thank you.
IIRC there are two, either tied to fronts and rears, or left and right pairs (if I was home I'd go down and look). Either way, just look at the labels on the inside of the fuse box lid in the engine compartment - you'll see it.
Fabio-Z06 (02-02-2017)
Quick Reply: [Z06] Oxygen Sensor bank 1 sensor 1
