Floor jacks
Floor jacks
Can anyone tell me what floor jacks work with a Grand Sport. It is low and I cant get my jacks under it. I have looked but have not found one
Get the low profile jack from harbor freight made by Pittsburgh.
Pittsburgh® Automotive 60678 2 ton Heavy Duty Low Profile Floor Jack with Rapid Pump®
Davidmcc (01-18-2017)
Might want to look at the Harbor Freight long reach low profile jack. I have their 3 ton low profile and I'm sure I couldn't get it far enough under the front of my base '09 to get it safely off the floor.
2020 C6 of the Year Finalist - Modified
Jacks
Try driving the front of your car on some small 1 X 10's or what ever size you need to get just that little bit of extra room.
Received 3,087 Likes
Most people would like to lift the car from the very front center of the car and then put jack stands under the two front / side jack points to the rear of the front wheels.
I may be wrong, but I am thinking that the low profile jack that 'MH663' mentioned may not be long enough to be used straight down the very front of the car.
On the other hand, you can buy a very similar jack, but a jack that is longer .... Because of it's increased length, this jack can be pushed straight into the front center of the GS and lift it up in order to install jack stands under the front / side lifting points.
Check this out ...
___________________________
2 ton Low Profile / Long Reach Steel Heavy Duty Floor Jack with Rapid Pump
http://www.harborfreight.com/2-ton-L...ump-68050.html
Davidmcc (01-20-2017)
Received 1,675 Likes
I got a low profile jack from Harbor Freight.
I found a great extra low profile jack on Amazon: The Arcan XL2T Black Low Profile Steel Service Jack, 2 Ton Capacity. I use it with poly pucks. Not familiar with the center lift point, to know if this would reach that or not. Link below:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Note: When I got mine, the price was $217 with free shipping - not the current price plus a huge shipping fee. I almost never pay for shipping directly.
Most of us have the 1.5 ton aluminum jack from Harbor Freight. You can find them on sale with the 20% coupon for $59. It will not go under the front but it will from the back. What you do is lift the car from the side using jacking pucks. These little jacks are very durable and almost bullet proof. For $59 you can't go wrong.
Floor Jack
Btw, I receive no compensation from myliftstand but I like excellent ideas/products made in America if I can find them.
I'm currently considering the Daytona floor jack from Harbor Freight #63183 a 3 ton unit to raise my 1970 C3 up. It has a raising height of 23 1/8" inches. I bought and you may consider also lift stands from a site called MYLIFTSTAND.COM the fella's name is Bill Gibbs. Received them yesterday and are of excellent build quality, I'm looking forward to using them. Good luck with your choice.
I have the Harbor Freight Pittsburgh 3 ton low profile jack as I use it on my 4X4 truck as well as the Vette. I have a set of jacking pucks that I use when lifting the Vette.
I have a GS and I've posted this before. If you have the $$, buy a pair of Trax Jacks from Race Ramps. They are small, 3 pound, ramps that fit under the GS and lift the car about 2 inches. This allows you to fit almost any jack under there. They are about $80, so more $$ then a piece of wood, but very small, lightweight, and even easily fit in the car. Great product. Good luck.
