Door impact sensors
Door impact sensors
I have a 2011 ZR1 after removing the door panels I noticed a harness that was not connected to anything near the mirror. The harness was taped off in what looked like factory heavy sticky tape. Im assuming this harness is for the door impact sensor since I don't see one.
Question is why is there no door impact sensors?
Also on reassembly whats the trick to get those pesky clips to engage at the top of the door panel?
Race Car Tech
Race Car Tech
As far as the side impact sensor for the air bag deployment, there is only one in each door, towards the rear of the door #18 as per the diagram below and the call out. The passenger door is exactly the same .
Passenger door - impact sensor #10
Just for added info, the C designation is for Connectors ie: C501
and S designation is Splices for wiring ie: S539
what do you suppose this connector is for? as I said it is taped up to the power mirror harness right near where the harness goes out the door to the mirror. I just happen to have a impact sensor and the connector is almost the same .
Race Car Tech
If your not having any issues with mirror dimming, or defrosting, etc, or any component in the door not working, I wouldn't worry about it.
I'm asuming that your ZR1 is loaded with all the options?
Most connectors look similar, but it's the wiring to those connectors that determine their pupose.
Here are all the impact sensors on your car
If I have the panel off anytime soon, I'll have a look, and report back to you on here and by PM.
hitekcm (01-19-2017)
xm antenna is the only thing I can think of.
Race Car Tech
That is a possibilty, but according to the servvice manual, that connector for the xm antenna is just behind the rubber boot seal in the side panel inside the car where the cables go through to the door.
I just may remove my panel, because now I'm really curious
The yellow connector, in the picture above this post, I would think??
Is your car a 1ZR optioned package? Do you have a memory switch for the seats and mirror positions?
I used the your shoe string method worked great, thanks
