sound deading
First of all, make sure it is road noise, rather than sway bar end links, axle nuts, loose/worn shocks, CRAPPY TIRES!, targa top, "rocking" chair/driver's seat, etc.
The forum has easy, simple fixes for all the above, and I mean really simple. Just do a search for any of them.
Race Car Tech
Nothing will stop all of the noise, but it can be greatly reduced for sure.
1) Dependiong on your tires, and how much they are worn, is the "major" contributor of road noise for sure. (What tires are you running with?)
2) Sound deadening material such as Dynamat, or similar products will deaden any outside noises coming through the plastic liners or body panels to the interior.
3) just ahead of the rear wheels, is a cavity void with a small bag of insulation to try to alleviate the noise carry from the rear tires, but it's too little to actually prevent all of it. - filling that void with an extra large bag, or other insulation will help some.
4) A rear partition will help keep some of the noise in the rear hatch, rspecially if you also have the cover for the hatch window closing off the rear completely.
Good Luck in the endeavour.
Inside doors.
Inside hatch and behind seats
Inside wheel wells behind liner
I used Noico 50 and some 80 mil inside car and Peel and Seal outside. Dynamat is way over priced as are some of the other products - in my opinion.
True Knight (02-23-2017)
Thanks
My car is loud. Gutted cats. 408 cid. Corsa sports.
IMHO..... and, I've got it all...... dynamat, an acoustical mat in the back and behind the seats..... nothing really works as advertised.
A waste of time money.
Just sayin'
Just sayin'
Race Car Tech
As mentioned, with the rear liners removed, you can install Noico type material above the liner, on the metal/plastic panels in that cavity, and put more bagged insulation to fully engulf that cavity to try to prevent as much tire noise sound travel as possible from outside to inside the vehicle.
There is no end to how much you can use, but as mentioned, the noise will never be completely eraticated.
Here is a pic to remove the rear wheel liner.
The following 2 users liked this post by 4SUMERZ:
88redconvert (02-19-2017),
Vet Interested (02-19-2017)
Here's a picture of the cavity area behind the passengers side door. There's one on the driver's side too. I lined it with Peel and Seal then put the factory foam roll back in. All this sound proofing works great for tire and road noise. It even helps keep traffic noise out. But if anyone is trying to stop exhaust drone or muffler noise with this method I think they will be disappointed. Also, if you do this area, seal the gap between the lower panel and the upper panel so that you don't have tiny pebbles showing in the gap all the time. Best regards
The following 3 users liked this post by montman:
If you remove the rear wheel liners, you will then see the cavity in the front of the wheels and the bag of insulation (wrapped in black plastic) put there from the factory.
buckmeister2 (02-20-2017)
The following 3 users liked this post by Travlee:
alrighty, finally got it in. obviously super simple to put install, in a 10 min trip to the store... noticeably quieter. i have LTH, high flow cats, and factory npp. to me it sounded like i had the flaps closed.. maybe even more quiet than that. one thing that i don't like, (easy fix and technically a non issue) is that unless you have a mat to cover it i could see it ripping easily with things you place in the hatch. if you have the Lloyds mat, i think you would have the perfect combo.
Tomorrow the car is going to have the Borla ATAK installed, so when transporting the exhaust to the shop i will take out the BlockIT. after the exhaust i will get to see what it sounds like without the mat and then with it later. is it worth the $230?? to me yeah, because i am lazy don't want to pull all the carpet out.... so with that being said, money well spent to me
TKO Performance (02-26-2017)
agreed but not sure if I have seen many posts over the years referring to that location as a "troubled area". Always see talk about transmission heat but not much about road noise. I got an extra box so I guess I should stop being lazy and just do it....
I guess it's all relative. Aside from the exhaust note (which I happen to like), my '08 seems quiet as a tomb compared to my '05 Carrera. Wind, tires, road bumps, rattles...all of it is twice as loud as the Vette.
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
The top layer is surprisingly tougher then you think. If you try to pick at it you will find it won't tear. But yes, many do place a Lloyd mat (or similar) on it for simply the esthetics.
Thank you for your business, and your kind words and for the time you took to post!
Ed
