My C6 locks itself in park
Old 02-21-2017, 07:38 AM
skewzme
skewzme's Avatar
Default My C6 locks itself in park
I own a 2005 automatic coupe.
The shifter occasionally locks itself in park.
Yesterday, for example, someone drove the car up to me in a parking lot,
opened the door and handed me the keys without turning the car off.
I get in, close the door, and the car will no shift out of park.
The only solution I found was to turn the car off, get out, close the door, open it again, get in, close the door, and then start it. It's like I have to mock the process of getting in the car and starting the car from scratch.
It once happened to me at a traffic light with cars behind me. I had got out of the car to grab a jacket out of the trunk. Made it back behind the wheel before the light changed to green, but the car wouldn't budge out of park.
Love the car, but way too much electronics.
Any idea what's going on here or how to fix it?
Old 02-21-2017, 08:22 AM
EVRose
EVRose's Avatar
Do a search for "stuck in park". Many, many threads on the subject. Here is one.
https://www.corvetteforum.com/forums...k-finally.html
Old 02-21-2017, 08:44 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Common issue. Mine did it Saturday. I push forward slightly on the shifter and it clicks. I need to find time to do the permanent fix before it fails completely but it's been doing it for a year and it works most of the time and only requires a small push to fix.
BTW, DO NOT GO TO A DEALER FOR THIS FIX!!! It gets expensive for a trivial issue and the fix the dealer will do will be to replace the part with the same faulty part design. The zip tie fix works as long as you own the car.
Old 02-21-2017, 01:51 PM
nick14003
nick14003's Avatar
probably the solenoid in the shifter
even something as trivial as spilled soda or gunk build up can mess it up
take out your center trim, pull out your shifter, disassemble it entirely, clean everything up, put it back together, might be good after that, if not change the solenoid in the shifter, or just buy a whole new shifter which is the most expensive option.
Old 02-21-2017, 01:58 PM
EVRose
EVRose's Avatar
You like to do things the hard way, huh?
Old 02-21-2017, 02:17 PM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
either hold the pawl back with wire or cut it off all together, some have attached wire to it threaded to the center console, so they can pull it back when it does jam.
I snipped mine off.
Old 02-21-2017, 03:51 PM
cmonkey713
cmonkey713's Avatar
Received 1,251 Likes on 916 Posts
Yep! this is it. I just did mine a couple of weeks ago.
To My C6 locks itself in park
Quick Reply: My C6 locks itself in park
