Disabled my shift lock...finally.
Old Sep 9, 2013 | 01:39 PM
EVRose's Avatar
EVRose
Default Disabled my shift lock...finally.
It's been getting worse and worse and after being stuck for half an hour on Saturday I decided enough is enough and disabled the shift lock on Sunday. Took about an hour. Did not have to take the console all the way off. Only disconnected the active handling switch harness and the passenger seat belt light then propped the console up on the e-brake handle. The red thing is propping the shifter cover up.
Here's an updated picture.
Old Sep 9, 2013 | 05:53 PM
AIR_RAM's Avatar
AIR_RAM
I dont get it... exactly what did you do to eliminate it?
SPEED SAFE, AIR RAM
Old Sep 9, 2013 | 05:58 PM
dennis50nj's Avatar
dennis50nj
SPEED SAFE, AIR RAM
he zip tied the locking latch open, i just snapped mine off, the solenoid raises the latch
Old Sep 9, 2013 | 06:00 PM
Knowklew's Avatar
Knowklew
St. Jude Donor '13-'14
things like this make me glad I have a M6
Old Sep 9, 2013 | 06:12 PM
dennis50nj's Avatar
dennis50nj
and things like this make me glad i have an automatic
External Engine Modifications LS2 (Bolt-Ons)
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944)
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
10.936 @ 123.01 - Dicky - 06 A6 - CAI, conv, cutouts, fast, 3.42, hdr, & more tune, DR - (5485)
11.121 @ 124.49 - Teetheriot - 07 A6 - CAI, conv, fast, hdr,nc , Z06 muff, & more, tune, DR - (5869)
11.293 @ 122.24 - JMT1669 - 06 A6 - CAI, conv, cb, fast, 3.42, hdr, tune, DR - (4427)
11.295 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, conv, Pfast, hdr, no cats, tune, udp, DR - (5105)
11.342 @ 125.78 - Silvervette05 - 05 M6 – pfast/tb, gto skinnys, Z06 exhaust, tune, DR - (4422
and this
Internal Engine Modifications LS2
10.157 @ 129.43 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdr, ptb, Z06muff, tune, & more, DR - (6370)
10.163 @ 131.08 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, H&C, hdr, ptb, tune, & more, DR - (6493)
10.585 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast, 4.10, H&C, hdr, 100maf, tune, DR - (4330)
10.665 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, pfast, 4.10, hdr, H&C, tune, DR - (4296)
and a good clutch cost more than a built automatic trans and no need to shut down in reverse
Old Sep 9, 2013 | 06:57 PM
Knowklew's Avatar
Knowklew
I guess if I drag raced my car the 1/4 mile times would matter to me, but I don't. So I stick with my statement that I am happy I have a M6.
Old Sep 9, 2013 | 07:47 PM
EVRose's Avatar
EVRose
I'm totally happy with my A4. This was not a tranny problem. There is a little solinoid that locks the shifter in park until you step on the brake. That solinoid goes bad and you cant get out of park. Someone on here, I cant remember who, found a work around that involves strapping the locking pin back so it cant engage and lock the shifter. Simple procedure and makes it impossible for the shifter to get stuck in park any more.
Old Sep 10, 2013 | 02:22 PM
irok's Avatar
irok
your right if you want to be slow thats the way to go
Old Sep 10, 2013 | 03:56 PM
Drewstein's Avatar
Drewstein
Yeah because trapping 133mph is where it's at. Call me when you trap in the 160 range like my M6 does.
Old Jan 16, 2014 | 01:37 PM
Brassbender43's Avatar
Brassbender43
I had this problem on my 05 A4. I could not get at the locking tab to drill a hole in it for a tie back. I placed the round section of a tube key over the solenoid shaft to keep the shaft in the extended position, thus keeping the lock tab out of the way. I cut the tube key down to length and crimped it around the shaft. This is a permanent solution. Just remember to always keep your foot on the brake when starting the car. Total cost for the tube key was $3.00.
Old Jan 27, 2014 | 12:28 PM
lght spd's Avatar
lght spd
Thanks for the information. I am completely locked out of reverse on my 2005 A4. This is good info.
Old Jan 27, 2014 | 01:17 PM
EVRose's Avatar
EVRose
Your welcome! There is something you can try before you do this fix. I used to be able to get mine to release by pushing the shifter forward with foot on brake until you hear it unlock. Then push the button and pull it back into gear. It got to the point on mine where that didn't work either so I went ahead and disabled the shift lock.
Old Jan 27, 2014 | 01:37 PM
dennis50nj's Avatar
dennis50nj
Are you just locked out of reverse or also drive, in other words is it stuck in park
Old Jan 28, 2014 | 04:32 PM
lght spd's Avatar
lght spd
Yes my personal situation is I'm completely stuck in park.
Does anybody have a reverse lock solenoid replacement part number?
Old Jan 28, 2014 | 05:23 PM
EVRose's Avatar
EVRose
The solenoid can not be replaced unless you can find a used shifter and pull it off from there. If you took your car to the dealer to have this fixed they would replace the entire shifter assembly for between $400-$600.
Old Jan 28, 2014 | 05:50 PM
dennis50nj's Avatar
dennis50nj
they dont sell just the noid you have to replace the whole shifter, they say you can put the car in acc mode and still shift it out of park, it didnt work for me. I like it better with the latch cut broke or zip tied as you can now have the car in neutral with the power off
Old Feb 1, 2014 | 10:38 PM
ufso's Avatar
ufso
Originally Posted by LV2TOUR
Just so all the Auto trans owners understand, this fix is only for the 2005 A4.
The 2006 -2013 A6 does not work this way. The A6 cannot be taken apart and is a sealed unit. The A6 does not have the locking issue as the A4 had as far as I know.
I just had my '05 and my friends '07 done today. We snipped off the offending part and it took about 35 minutes for each car...WE'RE BOTH REALLY HAPPY CAMPERS NOW!!!
To Disabled my shift lock...finally.
Old Feb 2, 2014 | 01:35 PM
v8rx7com's Avatar
v8rx7com
I did this "fix" on my 2005 a couple of years ago.
I offered to help Sparky (ufso) to do the same "fix" to his 2005.
A mutual friend of Sparky and I was having the same problem with his 2007 A6.
After reading several forum posts about the 2006+ A6 shifter being different, I was not sure if we would be able to do the same "fix" with the 2007, but we were willing to give it a try.
Turns out ....the 2007 A6 shifter has the same solenoid controlled latch that fails in the 2005 A4 shifter and the "fix" was the same.
I'm using the word fix in quotes ("fix") because by doing this "fix" you are disabling the shifter lock mechanism which is considered a safety feature (do so at your own risk). The "correct" fix would be to spend a lot of money to replace the whole shifter assembly (that could fail again).
If that is the case, then I'm awfully happy that I was wrong about being able to do the A6. When I had my A6 apart, I could not get into it, but I didn't want to break anything, so i didn't force anything. I know that the A4 is right there in front of you.
To get to the
Can you share how you did the fix on the A6? If so, you will be the first to ever have the fix documented. pics would also be a great help.
Many thanks
Two helpful hints that I didn't see anyone else post:
#1 - After you remove the radio surround, as seen here:
http://forums.corvetteforum.com/c6-t...l-removal.html
You also need to remove the shifter boot housing, there are (2 prong) release clips located on the shifter boot housing (one towards the dash side and the other towards the center console side). To release these clips, you need to pinch the tabs together while pulling up on the shift boot at the same time. We used 2 small flat head screw drivers at both sides of the tabs to push the tabs together.
Here is a drawing I made to "hopefully" explain this better:
#2 – Make sure the orange shift indicator (the indicator that shows you what gear you are in when you shift gears) is working properly before you reassemble everything back together. The shift indicator connects to the shifter via a small round tab that is inserted into a hole in a plastic part located on the side of the shifter shaft. It will likely come un-done when you pull up on the shift boot. It’s easy to put back together, but it can also be easily overlooked during reassembly. The red arrow below shows where the shift indicator comes disconnected from the shifter.
Old Feb 2, 2014 | 06:29 PM
ufso's Avatar
ufso
Thank you so much Pete for posting, "THE FIRST EVER DOCUMENTED WITH PICS" repairing of the A6!!!
Old Feb 3, 2014 | 09:12 AM
Justasheet's Avatar
Justasheet
I agree, nicely done! I never new they were the same.
Jeff
